Installed Eibach Springs
jeez thats low...be glad you dont have the OEM kit because the front would be sitting on the road in those pics...trust me i know I've kissed concrete with my lip and i only have pro-kit...looks hot
![Talking](https://acurazine.com/forums/images/icons/icon10.gif)
Eibach 1.9 front, 1.6 rear Sportsline with rubber bushings in the rear. Alignment was done at the Acura dealer, no camber kit needed, and drives just as smooth as factory with better control, especially when turning corners. I chose Eibach because that is what the german car manufacturers (BMW, Mercedes) use for their sports suspension.
Tein has taken over this forum, but without coil overs you wont ge that low on Tein and the drive isn't has smooth as Eibach's.
Thanks for the great comments.
Just dial 1911
1 Post
DAMN!!!! That looks nice.... I was going to with go 2 in the front 1.5 in the back but now that i see your car Im going to go with 1.5 in the front and 1 in the back because of my lip kit... Very nice... Now you got to be very careful and not drive fast on roads you dont know.
True, depending on your mileage. the installer told me i would need strut in 6 months, maybe less. So yes i will be installing struts in about 2 months
a camber kit is also required for the front?
from other threads, it's been mentioned that because of the double wishbone set-up and geometry, a front camber kit is not required.
do i have my info mixed up?
Bit*h get in my car
Your camber in the front is gonna be off but if I remember clearly, JTSO said you will have about .5 inches less clearance on the bottom and that could cause some damage if you were to hit something...
Look at the big nut on top of the ball joint.
Look what happens if the car bottoms out. I don't remember bottoming out but just imagine if I did. The big nut reduces the overall suspension movement of the upper control arm. The sheet metal actually pushed up slightly from this dent.
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
