How low can you go?
How low can you go?
So i just got back from the shop, had my tein basic installed! The install went smooth and my car is slammed. I have about a one finger gap in the front and a lil over a finger in the back. Im thinking this is a bit to low so im gonna adjust it the next chance i get. I was just wondering to see how low you guys have gone? maybe some pics would be helpful. Really any advice would be greatly appreciated! thanks
I am lowered on springs, shocks and a set of 18x8's. I have about two finger gap in the front and roughly two fingers in the back, that’s the lowest I have gone obviously.
Post some pics of your new drop
Originally Posted by Gunner11311
Lower it until you can turn the wheel all the way to one side and the tire is touching the fender, thats when you know your at the correct height.
You'll know you've done it right when you go over a small bump, and you can hear your wheel touch the wheel well
Stock tires, to give you an idea how low it should be!.. at least!
Originally Posted by VorteC
LOL you guys are so frikin slammed. I'm at 1 finger gap in front and 1.5finger in the rear, and it's the lowest I'm going to go in this damn city.
i tend to hold up traffic occassionally... because i have to wait for the opposing traffic to drive past.. so that i can go sideways over a speedbump
Originally Posted by etarui
Here's my lowest.
I raised it a little, and drove around like this for a while:
And then settled with this:
^that is sick!! if only if it was practical
perfect drop! how were you able to drive like that without scraping the wheel well the whole way while driving?
I've tried going that low, but it scrapes as soon as i move an inch :\
any fender work? wheel well removed?
....anybody know approx. how much it would cost for parts and labor to have them installed since he got it done free?
I would do it whenever I plan on getting my Tein's, but I just don't have any of the right equipment. I don't even have a floor jack.
most body shops are around 70$/hour. Usually takes 2-4 hours to do a coilover install (non-rushed)..
you could probably do it with a stock scissor jack... just do 1 corner at a time
just need standard wrenchs, and a good socket set, mainly
ugh, i have an annyoing squeak of some sorts coming from the passenger side rear wheel, i took that lil part of the seat off and i think its coming from the top of the coilover. any ideas??
here's some advice for those with a lower offset
1. push the wheel well above tab
2. use the handle of a hammer, or alike, and push the tab up so that it's bent up, almost alining with the wall of the fender.
it'll give you a good 1/2" of more room to play with from the tire - fender
and a good 2/3" or so of room to go even lower
I love your drop but Colts is right, it looks like there's no tire on there.
I'm at a tight finger gap on all four corners. I would like to go about a quarter inch lower but as it is, I only clear the ramp at my job's parking garage by less than an inch; I'm worried that if I drop my car any more my front lip is going to get destroyed.
Make a hole, coming thru!
Here's my lowest.
Originally Posted by samnguyen
nice car, where did you got for Mugen wheels? is your car still under warranty? they told me that if you put those after market wheels/rims on your car, it'll void the warranty. is that right?
On that note, wheels can't really do any harm to your car, unless you get something way out of the ordinary, but at that point, it'd be harm done caused by stupidity
On my CL I was tucking about an inch on the front and a little bit of tread on the back. The TSX is still stock but I want to get a drop like the OP's. Dbski, does it scrape a lot a the height you have it now?
i can't find any good pictures but about a finger gap in the front and no gap in the rear
-1 degree of camber w/ no mods in the rear
the front fender liner is starting to show some signs of "wear" haha
it's really not that low tho.. i can go straight thru speed bumps and dips. you know what that means... it's time to go lower.
if the car wasn't corner balanced, i would go lower.. a lot lower..
mad props to etarui!
I'd like to see how low my car would be if i went down all the way.... there's a good 3.5-4" before its set all the way down
Coils as it sits right now (that middle ring is tight now, i didn't leave it like that!! :o)
tucking half the tire more or less
wong05tsx, your TSX is sick! So clean. I'll snap a picture of my coils tomorrow. I've got a little bit left... I'm on Tanabe's and I've noticed a stiffer ride with the lower setting. I'm thinking about upgrading my suspension to handle the difference in travel and preload.
