how to clean coilover threads?
so winter is approaching and its around time to do some preparation job before it starts snowing.
i have a question regarding to the height adjustment for the coilovers. What do you guys use to clean the height adjustment threads before you adjust the ride height on your coilovers? When i had my coilover installed last summer i put some anti-seize coating on the threads. And last week when i jacked up the car I see alot of dirt builted up on the threads so i wonder what you guys use to clean off those dirt before you raise or lower your car.
Received 3,750 Likes
all i use to clean the threads is a wet rag. first clean off the visible threads. then use a tape measure to measure the distance from the start of the threads at the bottom to the first perch. this way you know where to put the purch back at. then lossen the purch and spin the purches a little and some dirt should come out. rotate the perch back up clean the lower threads again. now you should be able to lower both perches to the bottome and clean the whole threaded column. this is what I do with my TEIN Flex coilovers and I do it at every show I go to which comes down to being about 2 times a month however if you do it once a month or so you should be fine and just once a week during the winter I suggest just spraying them with with water to wash some of the dirt and salt off.
Originally Posted by Excelerate
Spray some WD40 on the threads and buy a wire brush (nothing too abrasive though) and clean them off that way. Then you could put some duct tape or something similar on the exposed threads to prevent surface rust, dirt, etc from building up.
dont know what black coating is on the TEIN Flex coilovers but they dont rust.
Got Milk???
WD40 is the best for the job, spray on, let it marinate for a few minutes. Then use toothbrush, brush off the dirt, when finished, just apply another coat of WD40 for protection.
KC
KC
Yep, tootbrush with flexi head/neck would be best option with some of your favourite car wash liquid (neat or with a small amount of water).
Rinse and dry - Robert's your mother's brother!
(Bob's your uncle, in case you cant' work it out!)
1fatcrxnem1
22
06-01-2018 01:23 AM
mugen_kid
11-13-2015 10:38 PM
nanos
11-12-2015 08:41 PM
