Eibach SPORTLINE KIT Question
Old Jun 24, 2006 | 03:47 PM
JAXFLTSX's Avatar
MAC USERS RULE
I am looking at getting the SPORTLINE KIT from Eibach and I was woundering if I need to get a camber kit?
Thanks,
Jason.
Old Jun 24, 2006 | 03:53 PM
TSX.Fury's Avatar
send me a link to JDM??
100% def
Old Jun 24, 2006 | 04:20 PM
JAXFLTSX's Avatar
MAC USERS RULE
Originally Posted by TSX.Fury
100% def
ok. how about if I got the pro kit?
Old Jun 24, 2006 | 07:28 PM
SoCaliTrojan's Avatar
Let me help you!
Suspension is very important. Save up the money and do it right the first time ;-)
I think you should be going for the drop you want...not the drop that lets you avoid getting a camber kit
Old Jun 24, 2006 | 07:31 PM
jiggaman's Avatar
I spend 2 much time here
sportline and stock shocks = rough ass ride
Old Jun 24, 2006 | 07:36 PM
JAXFLTSX's Avatar
MAC USERS RULE
I know.
Old Jun 24, 2006 | 10:30 PM
kwjustin89's Avatar
Thanks,
Jason.
You really don't NEED one IMO. Sure your tires might wear a little worse, but the touch of negative camber is actually beneficial to handling.
Old Jun 25, 2006 | 12:27 AM
TSX.Fury's Avatar
well... the toe effect is the bigger problem.
And yeah, you need some even with the prokit.
Old Jun 25, 2006 | 11:37 AM
AlterZgo's Avatar
You can adjust toe w/o a camber kit.
But, I would still recommend one b/c the camber gets noticeably negative w/ even a moderate drop.
Old Jun 25, 2006 | 01:41 PM
TSX.Fury's Avatar
hence it's not called a Camber+Toe kit
I was just stating...
Old Jun 25, 2006 | 07:44 PM
polytsx's Avatar
I have the Eibach kit and you can run without the camber kit, however you will accelerate the wear on your rears considerably. I will likely add the camber kit before I buy my next set of tires. I will say the handling, and in particular cornering is hugely enhanced, although you do inherit a rough ride.
Old Jun 25, 2006 | 08:13 PM
JAXFLTSX's Avatar
MAC USERS RULE
That is on the sportline kit correct?
Old Jun 26, 2006 | 02:14 AM
Distortion's Avatar
Walking the Line
I was riding on the Sportlines and Tokico Hp's on my Integra and the ride wasn't too bad IMO. But then again, this may be becuase i've spent a lot of time in trucks on airbags.
But seriously, the ride wasn't that bad.
Tire wear in the rear was an issue however and i went through a set of tires before fixing the problem with a camber kit.
Onyxthecat
Oct 18, 2016 02:05 PM
Zonian22
Nov 14, 2015 01:20 PM
mmhdavid
ILX Tires, Wheels & Suspension
Nov 9, 2015 11:18 PM
datadr
Sep 12, 2015 09:12 PM
Zonian22
Sep 2, 2015 08:19 AM
