Do I need a camber kit?
A definitive answer in a Heeltoe Tech Article!
http://heeltoeauto.com/httech/YaBB.p...1162587420/0#0
This topic is one of the most frequently asked on one of our major customer sites. So, rather than continue to post wordy replies over and over again, we are making it a tech article!
Do I need a camber kit? The short answer is: If you are worried about your tires, then no. If you are more anal about your car and want all the numbers correct, then yes. For the long answer, keep reading.
For Hondas, a camber kit is a debatable issue. When you lower the car, the camber will go out and you need a camber kit to fix it. However, I find it is not necessary to correct the camber in most cases. Most people think they need a camber kit because of a tire-wear concern. The reality is, TOE ANGLE kills tires WAY faster than camber ever will.
Sound like a bold statement? Conventional wisdom is that when you lower the car you need a camber kit if you don't wanna wear out the tires fast. Well, there is another adjustment/spec here than nobody has mentioned. Caster is another key.
When you lower a double wishbone car like the 88-00 Civics, 90-01 Integras, Accords, TSX, etc, the camber angle always increases in a negative direction: The wheels tilt inwards. It is what makes the car handle better in turns than strut cars. It is a natural effect of cycling a double-wishbone suspension.
Lowering many cars also increases the toe angle, which is to say it points the tires outward. They kinda fight for direction where the car wants to go.
But also, realize that all cars have some positive caster. The means that when you turn the wheel, the axis of rotation is not 90 degrees. You may notice it more exaggerated on BMWs and Benzes. The best way to view the angle is to turn the wheel all the way to one side, and get out and look at your car. Notice the wheel is turned, but also kind flopped over? Have a friend with a S500 (if you have one) do donuts while you watch outside. The wheels really flop over on those cars!
Think of it like pushing a wheel barrow. The angle from the axle to the handle is like caster. Pick up a wheel barrow and stand it veritcal on the tire with the handles straight in the air. Now imagine pushing it and trying to turn it. Haha...it just fell on you! Now imagine pushing and turning it normally. Much easier. Much more stable. And when you trun it, the tire is not actually turning. It flops over on it's side and leans! That is how your car turns too! That is how motorcylcles turn and well.
Caster is great for high speed stability. That is why all cars have some dialed in. Without it, the car would be super twitchy and hard to control at speed. It's why autobahn burners have more caster than your typical Japanese car.
The problem is, when you lower the car and toe angle is thrown out, the wheels are actually riding on the inside edges of the tire as they grind away pulling the car in different directions! This is in addition to the increased camber effect! With an improper alignment the car will WASTE tires in a matter of months (or weeks if you drive like me).
The trick to lowering the car and having the tires last is to get a good 4-wheel alignment to fix the toe angle. I AM COMPLETELY SERIOUS when I say that, as an authorized Tein distributor, 9 times out of ten we do not sell a camber kit. I have had over a dozen hondas, all lowered, and most lowered past 2". I have never had a camber kit on ANY of my cars. The ONLY car that I had a problem with tires with was my 94 accord which I had never aligned. Go figure.
Camber will tend to wear tires out somewhat quicker than stock, but generally speaking, with a good toe alignment, the increased wear will not be cumbersome or even really significant. The added camber actually makes the car handle a little better. Also, a little camber in conjuntion with the caster will wear the tires out almost evenly! So why get rid of it?
Here are some images to illustrate what I mean.
In this image, you can see where the inside and outside of the tire are. The red dots are there to help you identify the wear-indicators inside the tire grooves. When the tires wear down to these wear-bars, you know it is time to replace the tires. These tires are almost there:
![](http://www.heeltoeauto.com/files/tech/tirewear/thumbnails/IMG_0468.jpg)
Now, you can see how the tire is worn more toward the inside...that's camber wear. This customer was driving on this tire, with the car lowered moderately with a good alignment. He has not maximized tire wear, but clearly he has not greatly suffered either. No camber kit was installed.
In the next image, we have a tire which was lowered aggressively, and the car was NOT aligned.
![](http://www.heeltoeauto.com/files/tech/tirewear/thumbnails/IMG_0470.jpg)
Look how aggressively the tire has worn on the inside edge. The cords are even showing. This wear is caused by TOE angle. The direction of wear here is dramatically different than a camber-worn tire. This type of wear will kill a brand new set of tires in a matter of months. Mistakenly, people will lower their cars, not align them, get this wear, and blame it on camber. The timeline continues when the customer buys a camber kit, installs it, and the wear goes away. Must have been the camber kit, right? It was the toe, people. Also note, this is a front tire.
With a drop under 1.75", you should not need to even worry about it, because a drop of that much will not even throw the car out of factory camber specs! But that toe will be in the red every time!
Other things of note!
Camber and Caster are not adjustable on our Honda cars! I think we already know that , but I was just noting it. Toe is fully adjustable front and rear.
Front tires always wear faster than rear ones. The wheels back there are just free wheeling. There is little weight on them and the is no load/torque on them. Traction is not an issue and wear is nearly non-existant. If you are going to get a camber kit for your Honda, you only really need it in the front.
Some people wonder why Hondas do not have camber-adjustable pillow mounts available. The reason is simple. It's that Double-Wishbone suspension thing again. Cars which have camber adjustable pillow mounts awailable are all MacPherson strut suspension cars. In a MacPherson car, where struts are used, the damper locates the steering knuckle; it itself is a suspension member. In a Double-Wishbone car, upper and lower arms locate the knuckle, and the shock and spring are attached to one of the arms to provide dampening. So you see, with arms locating the knuckle, moving the shock around really does not change any alignment angles. So having camber adjustable upper pillow mounts on these applications is utterly pointless.
Alignment shops are like body shops. Most of them suck, but they are a necessary evil in our world. The trick is to find a good one you like. I hear a lot of good thigs about west-end. There are a couple in South Orange County here I recommend. I know a lot about alignments because I did them at work for a while. I wish I had an alignment machine JUST so I could do my own now!
Negative camber is visually apparent from outside the car. This is a big deal to some people. Likewise, I am not trying to tell people that lowering the car will not result in negative camber which is out of spec. All I am saying is that is does not have a big impact. Really, to fix the looks and alginment numbers, you'd need a camber kit. Some people just have different prioritys.
That's it for this posting. Thanks for reading! Feel free to reply!
Marcus
Marcus
You know, coming from a vendor that sells camber kits where you have nothing to gain and much to lose, I highly respect that you posted this
I PM'd you a few months back on picking up a set of Tein Basics, but will be postponing that to a spring '07 project.
Good info Marcus! My 4th gen Prelude is lowered without any camber kits. It has front and rear double wishbone suspension and front caster adjustment (rare). All alignment settings are within spec. My Yoko V4S tires are wearing so nicely after 30k miles, I only rotated them once, and it wasn't even necessary. So the most important part is to find a good alignment shop as mentioned by Marcus.
Let me help you!
How much can you lower a TSX before the rear wheels visually show your negative camber? I've seen some pictures were the wheels were definitely apparent. I want my car to have a 1-finger gap or possibly no gap...if the slant becomes visual only after lowering beyond this point, then I won't consider getting a camber kit
Nothing. The car has a little neg camber look stock, if you ask me... Any amount of lowing is going to show the camber.
I personally like the look of the camber. And really, it helps give you more tire-to-fender clearance to avoid rubbing.
Marcus
ridiculously good looking
just so i have all this right, the toe can be adjusted without buying any extra parts. and only the toe on the front wheels (on a FF car) need to be adjusted?
also, i think i read somewhere, that in order to get more "function" out of your front strut tower bar, you need to add camber to your front tires. is the stock camber -1? what kind of camber would i need to set it to, to feel an actual difference?
I got the camber kits to dial in what camber I wanted. It just so happens that the Ingalls has both lower bars and the cost was exactly the same as the SPC. I also found that there were many SPC kits going back because the rubber boot (different design than the Ingalls) was splitting. The SPC kit replaces the upper arm and is camber only.
You need the rear toe to be correct or the tires will wear.
And the alignment has pretty much nothing to do with chassis rigidity. However, with more neg camber, cornering forces can feasibly be higher, stressing the chassis more, necessitating a strut brace.....
The amount of camber you will want will depends on how hard you drive.
Someone stole "My Garage"
So if I were to drop the car a bit using Tein Basics, probably on their least lowering setting to start, I'd just need the Tein's, and an alignment from a good shop? No camber kit.
Also, I'd assuming every time I raise or lower the car, that would require a full alignment?
Thanks,
Eric
Thanks,
Eric
Thanks,
Eric
Thanks,
Eric
![Yes](https://acurazine.com/forums/images/smilies/yes.gif)
-2.x on both sides on STOCK.. should I correct this ? mechanic says i should.. what do you guys think ?
this is my last alignment
^^With -2.x rear camber, you'll experience more tread wear to the inside portion of the rear tires. Get the TSB regarding the rear camber done, then try another alignment. You should be at -1.0 on both sides.
Driven to Perfection
Marcus-
I've got a problem with my rears where the camber is around -1.5 to -2. The alignment shops I've gone to (one was Brake Masters, the other, a dealership) are unable to bring the camber any closer to 0. I have been experiencing tons of wear on the inside track of my tires - so much that I'm about to replace a set after about 20k miles. Is there an adjustment (caster) that can be made to help prolong the tire life?
btw, i'm currently on Kuhmo ASX 225/50/17 (wider than stock)
Originally Posted by mattster
Marcus-
1- They can't adjust the camber if you don't have a camber kit.
2- The wear is from toe. There is no caster angle in the rear because they don't steer.
3- The tires won't make any difference.
If the alignments you have gotten have not repaired the toe angle this is the problem. That offset in camber is kinda suspicious though. Are you lowered?
Evil
Just got aligned
I just put on my 19x8 volks... and installed the Tein TypeFLEX. I got my alignment done and they fixed my Toe on the front and back into the green.. but the camber is off by alot.. I read the post but was wondering if my rear camber is too high.. the front is good.. only in the red by 0.1 degree.. but the rear is in the red by 2.0 degrees on the left and 3.2 degrees on the right. Then the cross camber is in the red but the spec range is the same as the actual.
Here is a scan of the alignment:
![](http://forums.eastcoasttf2.com/uploads/1195750554/gallery_88_5_372670.jpg)
Evil
It's Mani BTW
Demos, you must be pretty low. The lower it is the more camber you will have.
At some point enough is enough and you'll want to fix it. Still monitor your tires to see if you are getting wear you don't like. If so, get the camber kit.
This is Mani from NY btw Marcus..
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
