Coilover Longevity
Coilover Longevity
I searched this and did not find much at all......, I was wondering how long a good coilover (like Tein) would last if it wasnt used at the track..., just on a everyday driver.... Will the performance last long under these conditions?? Or is it something that will not perform that well after some use? I guess it depends on who you ask....., but I wanted to here what people have to say....
when you say rebuild them......., what does that usually consist of....? and how much.....?? in comparison to the origional cost....
I've had 4 different sets of TEIN coilovers in 4 different cars. The longest one being the TypeHA (no longer available, been replaced by SS) in my Prelude. I had it on for 5.5 years and could've gone even longer without a rebuild. But I decided that I wanted stiffer springs and stiffer dampening for auto-x, therefore I had them revalved. I still have them on the Prelude. So far, it's been over 8 years (including the time after the revalving), and probably over 145k miles on them. They still perform good, however I might revalve them again. This time I want even stiffer springs and dampening for dedicated track use.
I'm not exactly sure what is involved in the rebuild process, but I think they normally replace and refill the shock fluid, and possibly replace the pistons and washers inside the shocks.
It depends on your driving and the road conditions. If you do alot of tracking or hard cornering, it will wear the coilovers out sooner. In fact, it's just the shock absorber that's going to wear. Springs generally don't wear out in a car's life expectancy. If you drive around where there are many potholes and bumps, it will shorten the life of your coilovers.
All in all, depends on your usage and the stress the coilovers are subjected to.
Agreed, and if you go by what the likes of D2 promote with theirs - million cycles and not one leak or problem, then as long as the springs are of good enough quality to minimise sagging (which they will do at some point), then 75K could be a very conservative guesstimate.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
4drviper
09-23-2015 07:42 PM
