Best Camber Kit to use with Tein Flex?
Old 01-04-2007, 03:08 PM
Special-K
PrecyseStylez's Avatar
Looking to get the Tein Flex and a camber kit but not sure which one works well with the set up... any help would be great. Thanks
Old 01-04-2007, 03:35 PM
hrj
hrj's Avatar
ingalls.. it has toe and camber adjustments..
Old 01-04-2007, 03:37 PM
jwood_06TSX's Avatar
^^ Yep!!
Old 01-04-2007, 03:54 PM
Time to Climb
godfather2's Avatar
ingalls all the way! and it's incredibly simple to adjust
Old 01-04-2007, 04:41 PM
Unauthorized User
VegaTSX's Avatar
Nobody here uses SPC cambers?
Old 01-22-2007, 03:50 PM
bluexcrush's Avatar
why ingalls? i thought ingalls, spc and eibach were on the same level
Old 01-22-2007, 11:15 PM
Bleser's Avatar
Yeah, what is the pros & cons of ingalls versus spc?
Old 01-22-2007, 11:28 PM
batboyvaj's Avatar
I have a new comptech front camber kit. I decided not to drop the car so have a set for sale.
Old 01-22-2007, 11:51 PM
etarui's Avatar
I got the FLEX's and the Ingalls. Guy at the alignment shop said they were very easy to adjust, and much better than some of the other kits he has seen out there.
Old 01-23-2007, 10:37 AM
Mugenpwp's Avatar
Even with an aggressive drop, a front camber kit is not necessary. The stock parts can be adjusted to within spec without an aftermarket kit.
The rear is different as a kit is required. The ingalls is the better one to get.
Old 01-23-2007, 10:39 AM
Just dial 1911
joerockt's Avatar
I have the SPC's, but the Ingalls are much easier to install IMO. You need a special tool for the SPC kit.
The main difference is the SPC replaces the upper arm. Ingalls replaces 2 lower arms.
Old 01-23-2007, 04:49 PM
Former Sponsor
Excelerate's Avatar
Yes, the SPC replaces an upper arm. Ingalls replaces 2 of the rear suspension arms allowing you to adjust camber and toe.
PM me if you need a set.
Old 01-23-2007, 05:54 PM
Chris_F's Avatar
I bought a front camber kit to increase front camber slightly, they arent only a correction part but also a performance part if your looking for a more aggressive alignment
Old 01-23-2007, 09:18 PM
Bye TSX, hello domestic?
xizor's Avatar
you need the spoon upper arms to get more camber in the front, the SPC will barely do it
Old 01-24-2007, 06:27 AM
moda_way's Avatar
Only negative I have noticed about the Ingalls is something JTso has mentioned before, the alignment guy absolutely needs to get the locking nuts as tight as possible. It requires a crows foot to get the proper amount of torque.
I also have the Ingalls front camber kit. There is almost no difference with the SPC kit for the front.
Old 01-24-2007, 07:49 AM
The guy who aligned my car at NTB last (not going back there btw) said that he needed some special tool to tighten it properly actually......how bad is it if they don't have this "crows foot" and is it going to come "loose?"
Old 01-24-2007, 08:04 AM
moda_way's Avatar
It is fairly important. I think my passenger side when out of spec last year and I got terrible tire wear. The problem with having a simple box end is that you have VERY little room to tighten down the locking nut.
Old 01-24-2007, 08:10 AM
Yea i saw the guy struggle with that but he improvised and made some odd looking contraption with a long pipe connected to the box wrench so he could get more leverage and more grip cause his hands didn't fit up there. It should be tight!!!....lol
Old 01-24-2007, 08:43 AM
moda_way's Avatar
Sounds good enough.
Old 07-22-2007, 10:46 AM
Chris_F's Avatar
They got me to about -1.9 degrees which was more than enough.
Having said that, I'm now considering the spoon arms because you can't be very low with the SPC kit installed.
MrHeeltoe
20
02-23-2023 01:54 PM
08KBP_VA
10-22-2019 01:55 PM
Jinkazetsukai
11-21-2015 05:28 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Best Camber Kit to use with Tein Flex?
