Avon tires?
Where have I been, I've used these tires on my motorcyles for years but never knew they made automobile tires. The bike tires are all made in Britian and have always been very good.
C'mon, man! Row yer own.
I'll be buying a set of M500's this spring. I figure I can use my OEM Michelins in the winter (I've actually had good luck with them in ice and snow) and the Avons in summer and just swap them on/off my wheels. Or, buy new wheels with the money saved on the Avons.
I have the M500 since june and comparing to the previous tires (Yoko AVSes100) I can tell you the differences:
M500:
1. Confortable and quiet.
2. More grip on the wet.
3. Better bump absorb.
4. Last longer.
With the ES100 you have:
1. Better cornering response.
2. Felt more secure at high speed.
My next tires will be the BFGoodrige GSport in 235/45/17.
Let you known, for now the avons are at a great price.
M500:
4. Last longer.
send me a link to JDM??
M500:
4. Last longer.
M500:
4. Last longer.
Here is a test comparing the Avon M500 to 3 other tires (including the Yoko AVS ES100)
http://www.tirerack.com/tires/tests/avon_tech_m500.jsp
Also, a couple of more tests (all on Tirerack)
http://www.tirerack.com/tires/tests/fuzion_zri.jsp
http://www.tirerack.com/tires/tests/..._wide_oval.jsp
Originally Posted by TSX.Fury
JW because I'm going to get the M500's for my next set of wheels, what made you feel more secure at high speeds with the ES100?
2. Less body roll on the turns.
1. Steering response is tighter and quick on the ES100.
Received 3,755 Likes
hmmm interesting. Thanks for the response!
I notice that the M500s are 25 lbs (in 215/50/17 size) and the stock Michelins are 23 lbs. That 2 lbs., especially on a tire, eats some wheel horsepower I think. Anyone have a sense for how much? I'm also looking at the ContiSportContacts, which are UHP all-season, highly rated on Tire Rack, and 22 lbs. Plus a higher tire-wear rating (400 vs. 280). Anyone have experience with the Continentals?
I think I answered my own question, Googling to find this analysis of rotational mass. It says, basically, that an increase in the unsprung rotating mass, like a tire, is equivalent to adding twice as much weight to the car's sprung, non-rotating mass. So, 2 lbs/tire = 16 lbs on the car.
I've also read, though, that the further from the rotational center (in this case, the hub) the weight is, the more effect it has on acceleration. I guess I just don't want to spend money on CAI's and exhaust, etc. only to decrease my acceleration with heavy tires. Thoughts?
CostcoFanAUS
09-18-2015 06:05 AM
