Aftermarket Endlinks
Received 3,769 Likes
Found this on another site and thought I would post it here since it has been a topic of discussion numerous times.
Originally Posted by Rizzi
I'm sure a lot of you knew or assumed atleast that fully adjustable endlinks made for other honda's should fit the TSX. But I decided to throw this out there for those people who want or need endlinks and dont feel like taking the risk i took by buying endlinks that just "look like they'd fit". After stripping my stock endlinks and realizing how crappy they were, I went to buy better ones but couldnt find much. So here's what I did, for $40 bucks shipped on ebay I bought good quality metal endlinks made by Blox that were fully adjustable. The ad said they would fit 94-01 Integras and 92-00 Civics. I have ran them hard for 3 weeks now and they've held up great! and they're adjustable for stiffness..!
![](http://i2.ebayimg.com/01/i/000/8e/d1/209e_1_sbl.JPG)
Those won't work without additional spacers. Otherwise, it will not bolt up and will make clunking noise.
Try these instead. http://www.tirerack.com/suspension/s...tion+End+Links
Bye TSX, hello domestic?
I used the "beefed" up accord ones on my 2004 that the TSB calls out and they worked ok, they're barely larger than the stock ones and probably the same as the 2006 ones now.
will there be any problems if I just upgrade the rear two and not the front two.
boost owns
I doubt it Colts, documentation on Tirerack's site says you only need beefed up endlinks if you beef up the sway bar. Since I doubt even you're nuts enough to touch the FSB, you probably can safely just do the rears.
Just dial 1911
1 Post
2+ years and still no problems with endlinks so I dont think I need to do this. But I know there were a few that had issues, so this looks like it will work quite (quiet?
) well...
kb1rl
09-30-2015 10:17 AM
xsilverhawkx
09-28-2015 06:51 PM
