245\40\18...will it rub?
Old 03-12-2015 | 07:20 AM
sho0z's Avatar
Hey guys, I'm buying some wheels, they're 18x9 +50 with 245/40/18 tires on them. My TSX is on ff2s and I'm dropped 2"-2.5", do you guys think thus will rub? Will I need spacers and what size of spacer? I do have a camber kit in the rear, not worried about the rear as much as I am on the front...any help would be appreciated!
Old 03-12-2015 | 08:00 AM
if it rubs, raise that mother fucker up.
its an experiment.
you're going to have to do whatever it takes for it not to rub, if it rubs.
this means if rolling fenders and cutting the front bumper tab to prevent it from rubbing, so be it.
the term "pay to play" comes to mind.
Old 03-12-2015 | 08:28 AM
sho0z's Avatar
its an experiment.
sorry, let me be a bit more clear, what I mean is, will it clear my coilovers? like will it slap the suspension with the high offset+245 width...I know I can raise it, the fenders are slightly rolled and tabs are cut/removed. I am wondering this because im sure i'll have to get spacers, but it will take some time for them to get to me, but I wanted to rock the wheels before hand. I have 19x8 235/35/19 right now and I had to raise it a bit, I am hoping I will gain a little more clearance with this new set, but wanted to see if anyone here had better knowledge of sizing/clearance than I do.
Old 03-12-2015 | 08:38 AM
here is an online offset calculator:
1010TIRES.COM - Wheel Offset Calculator
input stock wheel specs than proposed wheel specs and it will show you how far in the new wheel specs will move
sho0z (03-12-2015)
Old 03-12-2015 | 08:48 AM
sho0z's Avatar
thanks man! appreciate the help
Old 03-19-2015 | 11:44 AM
cphresh's Avatar
6th Gear
pretty sure your fronts will rub. i ran that tire size on mine, dropped on Eibach Sport lines with an 18x9 wheel
Old 03-22-2015 | 07:45 PM
gsrkiller's Avatar
Offsets kinda high. Might have issues with the wheels rubbing on the suspensioN
Old 03-29-2015 | 04:42 PM
sho0z's Avatar
UPDATE** These did rub with the drop I had on my car. I went ahead and purchased new tires, 225/40/18 and I have literally no rub and I dropped my car further 1" all around. Now that my alignment is all jacked up, I am about to buy new toe arms from HeelToeAuto...now if I could just find someone to do the work for me or for cheap lol.
08KBP_VA
10-22-2019 01:55 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
Tribalheads
09-29-2015 03:24 PM
Quick Reply: 245\40\18...will it rub?
