245\40\18...will it rub?
Hey guys, I'm buying some wheels, they're 18x9 +50 with 245/40/18 tires on them. My TSX is on ff2s and I'm dropped 2"-2.5", do you guys think thus will rub? Will I need spacers and what size of spacer? I do have a camber kit in the rear, not worried about the rear as much as I am on the front...any help would be appreciated!
if it rubs, raise that mother fucker up.
its an experiment. you're going to have to do whatever it takes for it not to rub, if it rubs. this means if rolling fenders and cutting the front bumper tab to prevent it from rubbing, so be it. the term "pay to play" comes to mind. |
(Post 15364476)
here is an online offset calculator:
1010TIRES.COM - Wheel Offset Calculator input stock wheel specs than proposed wheel specs and it will show you how far in the new wheel specs will move |
(Post 15364549)
pretty sure your fronts will rub. i ran that tire size on mine, dropped on Eibach Sport lines with an 18x9 wheel
Offsets kinda high. Might have issues with the wheels rubbing on the suspensioN
UPDATE** These did rub with the drop I had on my car. I went ahead and purchased new tires, 225/40/18 and I have literally no rub and I dropped my car further 1" all around. Now that my alignment is all jacked up, I am about to buy new toe arms from HeelToeAuto...now if I could just find someone to do the work for me or for cheap lol.
