235/35/19 Is Fit
Old 03-16-2004 | 11:02 PM
teddy's Avatar
235/35/19 Is Fit
hi everybody i just install a 19x8 45 offset grewalt EVO II with 235/35/19 toyo T1S on my tsx and everything is fine ,and i drop 2inch with Tein spring ,but i need to put a 3mm spacer in the rear because if u don't put the spacer it look the rear wheel will be about 2 inch inside the fender well.
PICS http://www.clubtsx.com/bbs/showthread.php?t=6099
Old 03-16-2004 | 11:23 PM
xizor's Avatar
Bye TSX, hello domestic?
good to know it fits, those are some tiny tires! how's the tire on a huge drop w/ thin t1s?
Old 03-16-2004 | 11:31 PM
teddy's Avatar
everthing is good ,but the steering feel more sensitive
Old 03-17-2004 | 12:30 AM
JTso's Avatar
Did you also install camber kits and alignment?
Old 03-17-2004 | 01:09 AM
teddy's Avatar
no ,but i will try to fix the alignment on this weekend.,let see how many off of the camber,
Old 03-17-2004 | 05:13 PM
JTso's Avatar
Okay, let me get this straight. The car is lowered two inches without camber kit or alignment. The tires are sticking in due to negative camber. So you used spacers to move the wheel back out?
Old 03-17-2004 | 10:37 PM
cmf's Avatar
cmf
ATCer
Those wheels are sick. Man that looks good. Nice choice of wheels!
Old 03-18-2004 | 02:42 AM
teddy's Avatar
becasue if u use the same offset in front and rear ,u will see the front wheel with be look more outside than the rear because is a front wheel drive car so i need to put the 3mm spacer in the rear to look more even with front and rear
Old 03-18-2004 | 11:39 PM
gavinn58's Avatar
STi'd
that is sick...nice job!
Old 03-19-2004 | 07:36 AM
DEVO's Avatar
How do you adjust the speedometer to account for the diameter difference. Or is it too small to have any big effect at lower speeds?
Old 03-19-2004 | 12:18 PM
vwong's Avatar
n00b
235/35/19 has roughly the same O.D. as the stock size.
215/50/17 - 25.46"
235/35/19 - 25.48"
Old 03-19-2004 | 04:14 PM
teddy's Avatar
yes ,the tire side is same ,becasue i don't want to messup the NAVI
this is the link u can check the tire size
http://www.miata.net/garage/tirecalc.html
Old 03-19-2004 | 04:59 PM
Dan Martin's Avatar
Photography Nerd
Navi won't be affected unless you are driving through a tunnel.
Old 03-19-2004 | 09:08 PM
teddy's Avatar
no ,the NAVI is measure the mileage and mph too,if u use a smaller tires, the speedometer and the mileage is off ,so the NAVI will off too. u can check on this link the tires size calculator http://www.miata.net/garage/tirecalc.html
Old 03-19-2004 | 11:38 PM
Dan Martin's Avatar
Photography Nerd
So Teddy you're saying that Navi doesn't use the GPS system to calculate speed???????
That would have to be the worst navigation package on the planet! I thought it used dead reckoning only when it couldn't get a sat signal like when you're driving through a tunnel. I fully understand how tire size can affect your speedometer and odometer.
Old 03-20-2004 | 12:51 AM
dzuy's Avatar
Troutslap Mod-DUH-rator
adjust? simple. drive faster hehe
emailnatec
29
09-28-2018 04:27 PM
vpasla1
09-17-2016 07:24 PM
ROWDY621
09-30-2015 03:20 PM
xsilverhawkx
09-28-2015 06:51 PM
Bielikb96
09-28-2015 10:45 AM
Quick Reply: 235/35/19 Is Fit
