18" or 19" Grey wheels
I have 17" OEM Grey wheels (liek Euro Accord), but they seems to be "small" :-))) Do someone know any 18" or 19" wheels that are grey colored ?
Registered AssHat
Re: 18" or 19" Grey wheels
dabuda:
I have a CG TSX and plan to buy those volks wheels. I'm not sure if I will go with 17 or 18 because I drive a lot daily (highway).
If I go with 18, do 215/45/18 will be good on Yoko AVS ES100?
I have those tires on the oem wheels and they bite a lot but the wear quickly.
Your recommendations.
Registered AssHat
Originally posted by kendroz
dabuda:
dabuda:
dabuda:
dabuda:
i have Nitto 555 225/40/18...this tire configuration is more common and thus relatively inexpensive. or if you want a little wider tire and more rim protection you can try 235/40/18.
Registered AssHat
Originally posted by dabuda2004
if you want to keep a smooth ride then get 17"s but the 18"s will look much better...since the wheel has a lip the wheels will look smaller, i've had a lot of comments that the the 18"s look like 17"s or even 16"s once in awhile.
hey, Lung fu mo shi
Do you think the bronze TE37 will look better on white?
I think still think between CE28N and TE37
seems that the CE28N doesn't look that good with high offset....
Registered AssHat
Originally posted by SAZABI
hey, Lung fu mo shi
hey, Lung fu mo shi
I think they would look okay and would bring out the "creamy-ness" of the white. But then I like the Mercury Silver.
JByron
01-08-2016 09:49 PM
