17 lbs wheels for CG
I cannot choose some quality wheels for my CG TSX. They must be lightweight (17lbs or less) and ET between 48 and 50.
Some guy at tirerack told me that ET less than 45 will rub stock tire (correct me if I'm wrong) and that 8 inch wheel on 17 cannot be fitted.
I drive 60 miles daily at the highway they must be strong.
Choices:
1. Enkei NT03+M 17x7.5 ET48 w=17lbs $301.00 ea http://www.enkei.co.jp/p_detail_nt03m.html
2. OZ SuperLeggera MTS 17x7 ET45 w=16.7lbs $280.00 ea
http://www.ozracing.com/usa/car/inde...am=3&wheel=14#
3. 5zigen FN01R-C 17x7 ET48 w=16lbs $200.00 ea
http://www.5zigenusa.com/wheels.html
4. G-Racing Seki 17x7 ET45 w=17.2lbs $185.00 ea
http://www.rdmwheels.com/gracing/seki.htm
And Finally these (if I have the money avai) :
5. Volk CE28N 17x7.5 ET50 w=14lbs $ 442.00 ea
6. Prodrive GC07C 17x7.5 ET48 w=15lbs $448.00 ea
http://www.prodrive-usa.com/product_...=11&pid=117&s=
And the one I Really like:
7. Prodrive GC06D 17x7.5 ET48 w=16bs $311.00 ea
http://www.prodrive-usa.com/product_...d=11&pid=71&s=
Any suggestions??
Choices:
Any suggestions??
I sure hope <45 offset won't rub, because I just spent $1435 on Velox PG-5S 17/7 +42 and hub-centric rings. They're only 12.2 lbs each, though. Should ship Tuesday, the guy said.
The fitment guide indicates that there may be issues under +45, but not necessarily.
The PG-5S is 17" only, but some of the other Pro-Gear series come in 18". I imagine when they name a weight, but there're two wheel sizes available, they mean the lighter (smaller) wheel. edit: Their page now says 12.5 lbs. Used to say 5.5 KG, which is 12.2 lbs. :P I'm not concerned with that kind of difference, though.
I thought the PG-5Ss looked the best for the TSX. However, they have a lighter max load than the various PG-Revs (620 KG for the PG-5S vs. 690 KG for the Revs).
To convert from KG to lbs, use Google and search for something like "5.5 kg to pounds."
I'm thinking about:
3. 5zigen FN01R-C 18x7.5 ET48 w=18-19lbs $200.00 ea
What do you guys think? Is 5zigen a pretty reliable company when it comes to their wheels?
kosei k1ts for lightweight cheap wheels. : http://www.liteswap.com/merchant2/me...ry_Code=wheels the offset is actually +50.
1fatcrxnem1
22
06-01-2018 01:23 AM
NBP_BALLER
09-23-2015 08:18 PM
