TSX on track v2 - Laguna Seca!
TSX Track Days
My TSX returns to the track, but this time at Laguna Seca! Just like last time, here's a nice GPS picture at the end of the day (sorry, lazy to resize, so just click on the pic)
http://www.jaxass.com/laguna/IMG_2942.JPG
Some comments about the day:
Track conditions:
GREAT DAY! Clear, sunny and a clean track. Recient rain had slightly messed up the edges of the track, but not a problem if you didn't go off. Track was less abrasive than buttonwillow.
My Car:
Bone stock 06 TSX 6MT. Trying to wear out the stock pads and tires before replacing them with Hawks & summers.
Stock brakes are not good enough, I'll need new fluid before going out again. Stock brakes stop great the first few zones, but slowly become weaker and finally mushy (possible boiling).
3rd gear is not quite long enough for this track, I ended up running out of gear a bit too early before several braking points. Worked gears 2, 3 and 4 quite a bit during the day. Max speed on the straight before turn 2 and before turn 8 was at most 90 mph. The straights are uphill, if they were not, 105-110 would have been easy.
I easly out paced my friend in a 2000 5 series... then I found out his V6 only puts out 197 hp
A bonus picture from the day!
http://www.jaxass.com/laguna/IMG_2850.JPG
I few of us plan on going back with a different group on the 12th of march. We'll have my TSX and a 07 Civic Si coupe. If anybody is interested, let me know and I'll send you the info to sign up. Let's get more TSXs out there!
Track conditions:
My Car:
"3rd gear is not quite long enough for this track, I ended up running out of gear a bit too early before several braking points."
I have similar issues when tracking my Integra Type-R. Solution is short shifting, you do not always need to shift at redline I was doing that every time in one section of Moroso here in FL last month.
TSX Track Days
Also, 4th gear on the uphills wasen't too good unless you shifted from 3rd around 6k. The RPM drop was pretty big, and short shifting at 5K would put you below the power band of the motor
TSX Track Days
The VTEC range on the stock TSX motor is definitely not ideal for driving at the track. The car definitely is not as much of a pig as my Type-R is under the VTEC range though. Can't have it all! Well, atleast from the factory
TSX_831, I'm up in Santa Rosa. My friend came up from LA.
Originally Posted by TSX_831
Laguna Seca is right in my backyard. It is about a 10 minute drive. Are you located here in the Monterey Bay?
i'll be moving back to salinas, in the next couple months.
Received 3,667 Likes
cant see them either.
TSX Track Days
Yeah, the host no longer works, but you can check out the other thread about the more recient Laguna Seca track day:
http://www.acura-tsx.com/forums/showthread.php?t=36677
mlody
12-04-2019 02:11 PM
GWEEDOspeedo
01-15-2016 10:39 PM
