Auto-X tires
Old Mar 12, 2006 | 04:07 PM
TodaSi's Avatar
Auto-X tires
What auto-x tires you all using? Only one i've found is the Hoosier but they are over $900 for all 4
Old Mar 12, 2006 | 04:48 PM
sauceman's Avatar
Moderator Alumnus
Not a bad price at all, considering the stock tires new will run you for more than that.
Old Mar 12, 2006 | 05:02 PM
CGTSX2004's Avatar
I understand that a lot of Auto-Xers like the Kuhmo Ecsta MX. It is relatively inexpensive and if you auto-x enough, a good inexpensive tire would be a great choice since you'll be changing tires often.
Old Mar 12, 2006 | 06:18 PM
xizor's Avatar
Bye TSX, hello domestic?
depends what kind of autocross tires you want. If you're doing SCCA and staying in stock class or doing a street prepared class you can use R-compounds. If you're doing a street touring class you need a DOT legal tire.
I can't comment on r-compounds as I only run street touring, but I suggest either the Hankook Z212, Kuhmo MX, or Falken Azenis RT-615. The Hankook's are easily the cheapest and seem to be the stickiest of the bunch. Check edgeracing.com for prices.
Old Mar 18, 2006 | 05:43 PM
TodaSi's Avatar
Planning on running a couple Regional Auto-x's this year. I believe the TSX is re-classed. Thinking of running a few events in stock class. Would I be cheating if I run with the A-Spec suspension in stock class?
Old Mar 19, 2006 | 06:48 AM
xizor's Avatar
Is it h-stock now? And yes, running the a-spec suspension is cheating
Old Mar 19, 2006 | 02:33 PM
TodaSi's Avatar
So I would have to run in street touring or swap the stock suspension back on.
In which case, may as well run street tires and leave it at that. Guess I can buy the Comptech re-flash, Euro R front lip, and a header while I'm at it.
Old Mar 19, 2006 | 08:38 PM
xizor's Avatar
Unless you plan on winning your region in stock class, you might as well run in street touring and have fun.
Old Apr 2, 2006 | 05:48 AM
PixelHarmony's Avatar
Master Graphic Artist
I'll be hitting up a autox this weekend. I only went once with the TSX, but what pressure should I put it at so it's enough to not tear up my tires?
Old Apr 2, 2006 | 10:36 AM
Firefightr86's Avatar
https://www.tirerack.com/tires/tires...ireModel=A3S05
Those Hoosiers are DOT Certified, so in SCAA AutoX the're still street class, even though they really are slicks... There was a 911 Running those last time I autoxed.... drove everyone in his class crazy because they were on regular streets... To be really competitive in AutoX, you gotta be running slicks
Old Apr 2, 2006 | 09:59 PM
xizor's Avatar
you have to have a 200 treadwear for street touring, r compounds are legal in street prepared however
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
DidiBob
Jan 4, 2016 12:41 PM
Robospinner
22
Sep 24, 2015 08:47 AM
CostcoFanAUS
Sep 18, 2015 06:05 AM
fallacy
Sep 4, 2015 10:15 AM
