04 tsx VS 06 tsx
Old 03-06-2006, 09:21 PM
The Power of a Grill
San-AnT's Avatar
Cool 04 tsx VS 06 tsx
background info:
Mine - 04 6mt tsx w/ injen CAI in short ram
His - 06 5at tsx w/ injen CAI in short ram
no other major mods
from a dead start on an old deserted road...
we both skip a little at go, but I get the jump. he starts to even out when I do a quick shift to 2 and pull away as his shifts. by 3rd shift i am at least 1 car ahead. by the end of 3rd i am at least 2 cars ahead and we let it go when i redline at 3rd. so much for the added horsepower.
comment: the 06 with CAI is sooo much louder than my 04. it seems like his (AT) is always loud, while mine (MT) is only loud when i give the gas a good press. Although my CAI has been in for at least 5 months, his was in for about 5 minutes (ok, 45). I had just installed his and his ECU may not have had enough time to adjust yet. But it was loud as hell.
Bob, don't be mad. once you get your header we can race again and then i will get my supercharger!!!
Old 03-06-2006, 09:51 PM
My Garage
GIBSON6594's Avatar
meh, MT>AT
Old 03-06-2006, 10:35 PM
fuckleberry's Avatar
is Bob on this forum ?
Old 03-06-2006, 10:52 PM
San-AnT's Avatar
he is now
San-AnT's Avatar
well, huckleberry, how did the in-car theater work out?
Old 03-06-2006, 11:00 PM
CGTSX2004's Avatar
This should have been a drivers race. The 06 TSX makes as much power stock as the 04/05 TSX with a CAI.
Old 03-06-2006, 11:05 PM
working on getting more hardware, thx for checking
Old 03-06-2006, 11:08 PM
San-AnT's Avatar
all he had to do was press on the pedal in AT. how do you screw that up?
Old 03-06-2006, 11:17 PM
CGTSX2004's Avatar
Failing to launch correctly, failing to shift (supposing he is using the SS mode) at the right point, forgetting to turn off the VSA, etc.
Sure it's an automatic but there are still lots of things you can get wrong.
Old 03-06-2006, 11:18 PM
San-AnT's Avatar
he wasn't in SS. we both left VSA on
Old 03-06-2006, 11:20 PM
3rd Gear
purplepeopleater's Avatar
Ha! 2 car lengths? You wish!
More like 1/2 car length. Must have been the adrenaline rushing through you that magnified your perceptions.
Driver/Detailer
aaronng's Avatar
Forgetting to turn off A/C
Old 03-07-2006, 02:24 AM
Master Graphic Artist
PixelHarmony's Avatar
Again MT > AT
Old 03-07-2006, 09:42 AM
jlukja's Avatar
Let the ECU learn the intake and then do it again. I agree with CG, its a drivers race and launch would probably determine the winner.
Hi Bob, welcome to AZine. Oh, and turn off your A/C
Old 03-07-2006, 12:21 PM
JTso's Avatar
I think the louder noise on the 06 has something to do with the larger TB and intake manifold. I also noticed the increased induction sound after the TB upgrade.
Old 03-07-2006, 12:35 PM
dom
dom's Avatar
Ok, but its still an MT vs AT.
Old 03-07-2006, 12:55 PM
My Garage
GIBSON6594's Avatar
I'll fix my original post
04-06 MT>04-06 AT & 06 AT
Old 03-07-2006, 01:09 PM
dom
dom's Avatar
04-06 AT & 06 AT
Old 03-07-2006, 01:31 PM
VSA Rocks
Black_6spd's Avatar
I dunno. I have a feeling it won't matter since the 5AT robs more power than the 13-15hp bump the '06 has at the crank. Additionally, the LONGGGGGG gears of the 5AT adds another disadvantage.
Old 03-07-2006, 01:33 PM
My Garage
GIBSON6594's Avatar
Originally Posted by dom
yea, left out the old >
Old 03-07-2006, 01:42 PM
CGTSX2004's Avatar
Dyno numbers show othewise. 06 5AT w/ CAI makes the same power as the 06 MT stock. The 06 MT stock makes about as much power as the 04/05 MT with CAI.
If anything was a factor, gearing was. But even that shouldn't have made that big a difference.
Old 03-07-2006, 02:37 PM
CarbonGray Earl's Avatar
I don't know about the dyno portion of it, however, I think gearing and transmission logic might have something to do with it as well. As stated, 5ATs have LLLOONNNGGG gears. Couple that with the fact that in D, in my experience, the tranny shifts up a couple of hundred RPM before I would, it drops you further from the sweet spot in the powerband. this isn't a good thing, esp with longer gearing.
Old 03-07-2006, 03:35 PM
VSA Rocks
Black_6spd's Avatar
I was trying to look up a few stock dynos for the 06 AT's, but no luck. I still have a hard time believing that they put more power at the wheels than a 05 6MT.
I forgot about 1 more factor -- low miles on the 2006 = less power. So, you pretty much have:
- low miles on 2006
- Less HP to the wheels (the 5AT was in SRI mode -- not CAI)
- Looooooooonnnnnnnnnnnnngggggggggg gears of the 5AT
Old 03-07-2006, 03:38 PM
Yeah I heard something about letting the ECU learn the intake. How do you properly do that? After the install I let my car idle for a while then I just took it out. I don't know if I have to do this every time I pull the battery off the car or not.
After my CAI install and winter coming around I've noticed when I push my car hard upon slowing down or stopping I have some pretty strong sulfur smells coming from my car. I still haven't figured out where the smell is coming from.. Buring too rich maybe, or the CAT maybe damaged?
Old 03-07-2006, 03:47 PM
CGTSX2004's Avatar
Nothing special to how the ECU learns. It's just a matter of driving the car normally for a couple hundred miles to give the ECU time to alter itself to the new conditions.
As for the smell, it's probably the cat.
Old 03-07-2006, 03:51 PM
jlukja's Avatar
^^ not an expert on this but it should adapt over the course of 3 - 4 start/stop cycles of driving. A cycle means starting the car, letting it warm up, driving it around, then turning it off. I would cycle with spirited driving, good pulls off the line throught the first couple of gears, to make the ECU adjust for performance rather than economy. My
My guess is that this is similar to when the ECU throws a CEL (check engine light) due to a gas cap that is not tightened properly. Once you tighten the cap you need to drive it a few cycles to let the ECU learn that the cap is back on correctly. Once it does the CEL will turn off indicating that the ECU has adaped to the new input.
Old 03-07-2006, 07:01 PM
San-AnT's Avatar
Talking
we shall see next time we meet.
Old 03-08-2006, 05:49 PM
C'mon, man! Row yer own.
peter_bigblock's Avatar
- low miles on 2006
I tend to agree, I think you have a combination of these factors. I think people tend to forget gearing when talking about this horsepower vs. that horsepower.
Old 03-08-2006, 11:46 PM
ATSX's Avatar
an auto vs manul= no contest. especailly on a torqueless car like the tsx.
Old 03-09-2006, 02:12 AM
I think the torque is good for a Honda
Old 03-09-2006, 02:13 AM
Damn, I guess it's about time to purchase a new cat.. Maybe JTso can fabricate another Metal' cat?
Old 03-09-2006, 06:41 AM
Moderator Alumnus
sauceman's Avatar
What kind of a race was that?
Old 03-09-2006, 10:01 AM
08 MDX with Sports
Newplay1's Avatar
Lightbulb
its only CAI when its in cold air intake form not when its in heat soaking engine bay SRI...
Old 03-09-2006, 12:13 PM
Reach's Avatar
Yeah I think they should go do it again and do it right this time
Plus, racing is fun! I wonder if you could neutral drop the AT, then swing it into SS mode before it shifts into 2nd? That would be the way to launch an AT. heh.
Old 03-09-2006, 01:07 PM
Rep'n Taxbrain.com
Tsx536's Avatar
Yeah I think it should have at least been a little closer. Let the ECU learn first of all, that's really important. And also he should race in SS mode. Good race though
Old 03-09-2006, 02:32 PM
VSA Rocks
Black_6spd's Avatar
Neutral bomb = for the poor tranny...
Old 03-09-2006, 06:46 PM
San-AnT's Avatar
yeah, i think we all know that. that's why i said it was in short ram. If i had typed Injen short ram, some smartass would have said that it is an Injen Cold Air Induction system in short ram mode....
Old 03-09-2006, 06:48 PM
San-AnT's Avatar
we will go again very soon. both in full CAI, both with A/C off and VSA off and his will be in SS. the problem is: what excuse will the AT drivers here have after i win that one?
Old 03-09-2006, 09:34 PM
Reach's Avatar
If he's worth his weight in salt, and you're not Helio Castroneves, you won't
Sorry, but the 06 made some good gains for minimal changes. Race me to find out... but I'll cheat and run you off the road
Old 03-09-2006, 11:17 PM
JTso's Avatar
I wouldn't mind run against a 06. I'll even leave my VSA on.
Quick Reply: 04 tsx VS 06 tsx
