Wire through firewall
Old Apr 9, 2006 | 09:36 PM
Goldorak's Avatar
Prince de l'espace
Question Wire through firewall
Hello!
Anybody has any idea on what is the best/easiest way to get a wire coming from under the hood, through the firewall and ending up in the little compartment where the switch for the VSA is?
I installed the JDM foglight kit and the only thing left for me to do is to connect that wire coming from under the hood to the rectangle switch.
Thanks.
Old Apr 9, 2006 | 10:49 PM
Alin10123's Avatar
If you look along the firewall the wires from under the hood should just about all go into the firewall from one central location. (at least that's the way my 4runner was). Just try to get through the firewall where the wires go through. Usually there's a rubber gasket around the opening. You may have to do some drilling to get some slack out of it so that you can get another wire through there. But it will work. Just use a coat hanger and stick it through first to see if you can see where it comes in near the pedals inside.
Acura604
20
Aug 5, 2017 12:55 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
