Windshield rattles -- 1 week at Acura for repair
Brought my 04 MT with Navi in for it's first oil change at 4K miles. Asked them to look at an alignment problem and rattle from the Windshield.
Three days later, and possibly after taking the entire dashboard apart (conflicting stories from dealer) they tell me I need a new windshield.
I've seen other posts about rattling windshields, but has anyone else had their windshield replaced? How about taking the dashboard apart? Makes me nervous.
Go Giants
Post #7 from this thread indicates they had their windshield replaced and the dealer installed a new windshield with brand new urethane and moldings:
https://acurazine.com/forums/showthr...hield+replaced
Go Giants
No ETA yet.
I brought mine in last week with the windshield problem. They said they were going to re-set the windshield and and "pinch" some spot welds in the cowl.
When I picked it up it had a new windshield in it and there was also some moulding listed on the invoice as being replaced. It has not been too cold here to tell if the problem has been fixed.
davidct were are you from and what dealer did you go too?
Originally Posted by wsklar
My dealer is refusing to do that. I spoke to them this morning and they are sure that Acura is developing new moldings for the TSX to fix the problem.
No ETA yet.
No ETA yet.
I understand if they say there is an offical fix coming out, I'd wait for that, but I'd want to confirm with someone else that there is a fix coming out and the dealer isn't just holding off on doing the work that other dealers seem to be doing hassle free.
I don't have these issues, knock on wood.
Just like to help out fellow A-TSXers.
do you have parchement? then knock on wood grain
Go Giants
Did you check with another dealer to verify this? Better yet ask for their regional Acura service manager so you can check with them to see when this fix is coming. Your dealer may just not want to do the work According to TSXCG, his dealer said it is a common problem and this is the best fix, so it sounds like his dealer has no problem doing it.
Found out today the Windshield has arrived but the molding has not. Looks like we're going in to next week now, with the Holidays and all.
I asked several times about the weather and how to guarantee the replacement windshield will be as good as the original (without the rattle). They told me it will be better than new, and they use only original Acura parts.
Am I paranoid? An Acura should tick well beyond 100K miles, and I am/was planning for that.
Go Giants
I'm from Connecticut and the car is at a local dealer (well respected dealer from the home work I did before purchasing from them).
My TSX has rattles that sound like they are coming from the junction between the cowl and both the A-pillar and the windshield. I get the rattles only when the outside temperature is below 55 to 60 degrees or so, and only when the air is dry. If it is warm outside or raining, the car sounds and feels solid as granite. Is that the same thing you are describing as a windshield rattle? Do the dealers have service bulletins on this?
Go Giants
Yes.
Soon, but not yet.
When I went to pick mine up it looked like they did the windshields on one or two other TSX's, probably for the same problem.
Go Giants
To let you know, the new windshield they installed in my car has the "Made in Japan" to be removed by end user sticker on it.
Did they say this would be a good fix?
Go Giants
They also fixed the cowl under the hood were we were sticking shims. It is now tight and
I can hardly move it.
I've not seen my car in over a week.
That is unusual that they took your car in without having the parts there. When I called to tell them about the problem, they made an appointment that was 3 weeks away so they had the parts and a loaner car for me.
TLDude876
12-28-2016 03:18 PM
rockyboy
01-25-2016 06:00 PM
