Whining Noise In Reverse (Video Enclosed)
Old Aug 25, 2011 | 07:42 PM
studville's Avatar
Doesn't Rice His Car
2006 Automatic TSX
Anyone have an idea what the cause of this noise is (only in reverse). It's coming from the rear of the car. Also I have a noise that sounds like metal scraping across a chalkboard at set intervals when I I'm driving forward.
http://www.youtube.com/watch?v=G8cOh8DHW7U
Old Aug 26, 2011 | 12:03 AM
PaHonda's Avatar
The video is set as private, so we can't see it.
I would check the rear brake pads. They are likely worn down to the metal tab that is supposed to make noises to let you know it is time to replace the brake pads.
Old Aug 26, 2011 | 09:36 PM
studville's Avatar
whoops
ok I changed the youtube settings... I think it's fixed now. The sound is pretty pronounced in the video
Old Aug 28, 2011 | 07:44 PM
studville's Avatar
Yep it was the pads... they were worn enough where the brake shims were rubbing against the rotor. I've replaced them and everything is good now.
On a separate topic, when putting in the new pads, how do you get the rear piston slits to line up with the "bumps" on the back of the pads? Is there some trick? It's hard to see and it's a pain in the ass
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
