Whining Noise
Old Apr 8, 2012 | 03:06 AM
sleepyeasy's Avatar
3rd Gear
Whining Noise
I recently bought a 2008 Acura TSX Nav/6MT with 48,XXX miles and today the car started to make a whining nose.
You only hear the whining noise when the transmission is in gear and gas pedal is depressed. That is the only time you can hear the whining noise.
I thought the problem would be a vacuum leak but the car sounded normal when it wasn't in gear.
An also when I shift gear it makes a harsh noise every time it catches.
Old Apr 8, 2012 | 10:51 PM
sleepyeasy's Avatar
3rd Gear
I asked a couple of friends today about the noise and they said the problem could be from the power steering pump o-ring. would that be a problem that makes a whining noise when accelerating?
Old Apr 11, 2012 | 06:53 PM
sleepyeasy's Avatar
3rd Gear
Today I asked a well trained mechanic and I told him about the noise. I forgot to mention in the earlier post that I did shifted into the wrong gear around 60mph and my tires spun.
He told me that the sound could be coming inside the transmission because of the high spike in rpm from shifting into the wrong gear that either a bearing was messed up or I burnt the transmission fluid. Can anyone chime in and confirm this could cause a whining noise?
Old Apr 22, 2012 | 10:49 AM
lancer's Avatar
TXSTATE BOBCATS
So the whine gets louder as the rpms increase? Turn off all electronics like radio and ac while driving and see if the whine stops. It could be due to your alternator.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
