Where is the Tranmission drain plug (AT)
Old Nov 8, 2008 | 05:55 PM
mars's Avatar
Hi All,
Could some one pls post the image of where the transmission drain plug is ...
I removed the Plastic shield and could see the Drain plug for the Engine oil but not for the transmission fluid..
thanks
mars
Old Nov 9, 2008 | 01:25 AM
FZ427's Avatar
Sorry no pic, the engine oil plug is on the left and the tranny one towards the right looking from underneath the car.
Old Nov 9, 2008 | 07:51 AM
mars's Avatar
Hi,
Thanks for the info.. I guess i am able to google for it and found a nice pic..
http://www.sexyracing.com/tilt/howto/rsx/trannyfluid/02b.jpg ( though it is for RSX i guess it will be same for TSX)..
thanks..
Old Nov 9, 2008 | 11:01 AM
mars's Avatar
Hi,
I searched the forum again and found a better picture in the thread below.
https://acurazine.com/forums/showthr...+funnel&page=2
mars
Old Nov 9, 2008 | 04:56 PM
mars's Avatar
Hi,
I tried to flush the transmission fluid (AT) and i couldn't screw out the drain plug. The manual says it's 5.0 kgfm - 36 lbf.
I used a click type torque wrench (3/8) and i set the settings mentioned and when i try to unwound it clicks..I even tried by increasing this to 5.6 and 40 without any luck..
what tools are you using to take out this drain plug..
thanks
mars
Old Nov 10, 2008 | 08:33 AM
npolite's Avatar
Mars, you'll need to a breaker bar and possibly a pole to get enough leverage to loosen it up; it's on there tight. You shouldn't ever use a torque wrench to loosen anything. Make sure to clean off any metal shavings that are attached to the drain bolt. It will look like a grey goo on the tip. Also be sure to put on a new washer and tighten the bold to the correct torque setting.
Old Nov 10, 2008 | 08:36 AM
78transam's Avatar
2005 TSX 6MT
Use a ratchet or breaker bar with a 3/8" head to remove the plug. Torque settings apply when replacing the drain plug.
Old Nov 10, 2008 | 10:12 AM
MMsTSX's Avatar
JDM Addict
Mike734
Dec 10, 2021 01:25 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
MetalGearTypeS
Aug 29, 2016 08:28 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
STL TL-S
Sep 23, 2015 08:52 PM
