VSA/ABS lights -> DTCs 12, 11, 61 & 83
Old Jul 29, 2021 | 03:49 PM
Lone Starr's Avatar
'06 TSX 6MT
Exclamation VSA/ABS lights -> DTCs 12, 11, 61 & 83
Hi All,
It's been a while since I've had post-worthy issues with my '06 6MT...
A week ago my VSA & ABS lights went on when I hit a bump going into a parking lot...
A few days later they turned off.
Then they came back, and now come on every time I start up.
Pulled the DTCs with the paperclip jumper on the OBDII port (12, 11, 61, 83).
My battery is OLD, but the car still runs fine, although I did have to recondition it after it sat unused for a year in the driveway.
But from what I've read, and DTC 61 being in the list, I think a new battery may be in order.
Once I do that, I'd like to clear the code to see if that does the trick- can I do that without an HDS (maybe with a fancier paper clip)?
I have a Bluetooth OBDII scanner that can clear CEL faults, but doesn't appear to do the same for the ABS/VSA codes.
TIA!
Old Jul 29, 2021 | 05:43 PM
when you pull the battery, it should clear the codes...
so, go get you a new battery and see!
Old Aug 2, 2021 | 03:17 PM
Lone Starr's Avatar
'06 TSX 6MT
removing the battery didn't clear the codes, but I was able to find my old HDS (and windows XP laptop) in the basement... cleared the codes, and 11 came back.
Old Aug 6, 2021 | 07:32 PM
Lone Starr's Avatar
'06 TSX 6MT
Well it's a permanent code now... went to replace the sensor and the plastic was so brittle after 15 years of northeastern winters that it snapped flush with the hub. I knew it was going to be nasty when the head of the bolt holding the sensor snapped off- I might be able to drill them out, but not sure it's worth it at this point...
Todd Gruchalski
4G TL Problems & Fixes
Nov 9, 2020 04:54 PM
Fred'sTSX
Dec 16, 2018 11:17 AM
CaliBud916
Oct 14, 2016 01:36 AM
ThomWV
2G CL Problems & Fixes
15
Oct 15, 2012 04:39 PM
wilsel
Feb 26, 2006 02:43 PM
