Vibration and Transmission Problem
Old May 28, 2010 | 02:42 AM
bibby_123's Avatar
Hi, I recently purchased a used Acura TSX 2004 2.4L Automatic 80,000 miles on it and I have a problem with it.
There is a big vibration in the car while you first start it and when it works in low RPM levels around 1500-2000. I have replaced all 3 main motor mounts to see if that could solve the problem but that didnt do anything. Now I'm not sure if the transmission mounts are causing this vibration problem.
The other thing is that the transmission has a 2 second delay when shifting to reverse from parking and or shifting to drive from parking. When I shift to reverse, I have to wait 2 seconds until it kicks it into gear and its jumpy. It does the same exact thing when I shift into drive. Also, when I drive the car and it tries to shift from second gear to first gear, there is also a delay, so the delay happens only when it shifts to first gear.
Could the problem result from a bad transmission solanoid valve, or could the problem be because of transmission mounts? I hope this is not a mechanical transmission problem. Can anyone help and has anybody had a similar problem? Thanks.
Old May 28, 2010 | 07:57 AM
Ron A's Avatar
Administrator
Welcome to the forums.
I deleted your post in 3G TL since you have a TSX, and also because you posted this thread here.
Old May 28, 2010 | 01:34 PM
Jottle's Avatar
Does your vibration subside noticeably once the car warms up and goes back to 750rpm at idle? Many of us have vibration when the car is cold in the morning and hasn't warmed up. This is a common "characteristic" of our cars and similar model year accords. There may be no solution if the vibration subsides once the engine warms up. Sorry I can't help with the gear shifting issues you're noticing.
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
