Vibration after intake install
Old Jan 10, 2006 | 01:47 PM
jerzpwr's Avatar
I already searched but couldn't find a answer... I just installed an AEM SRI two days ago and i feel a slight vibration from the steering wheel. I also feel a vibration from the brake when the car is in drive and my foot is on the brake. is this normal?
thanks in advance,
J
Old Jan 10, 2006 | 02:47 PM
Dan Martin's Avatar
Photography Nerd
I don't think the two are related.
Old Jan 11, 2006 | 07:12 AM
miner's Avatar
Right. Sounds like the WRS - Warped Rotor Syndrome. Not intake related.
Old Jan 11, 2006 | 10:27 AM
aaronng's Avatar
Driver/Detailer
First vibration is from your A/C. If you turn it off the vibration will go away. It's because you have the SRI, your torque at 700rpm decreases a little, so the engine vibrates (lugs a bit). The 2nd vibration is when you're in Drive, with the brakes and your car is not moving? If it is, then I suspect the SRI has magnified that vibration. It is the AT's torque convertor loading, so the engine also lugs a bit. With SRI, it is enhanced.
And if turning off the A/C doesn't work, check the points which secure the SRI for any loose bolts.
Old Jan 11, 2006 | 11:06 AM
jerzpwr's Avatar
thanks
Old Jan 30, 2006 | 09:18 PM
jtraha's Avatar
i just put a thread on this called vibration.... i mistankenly did it twice look at the one with the tory with it not the other one
Old Jan 30, 2006 | 11:34 PM
jlukja's Avatar
Link to jtraha's thread:
http://www.acura-tsx.com/forums/showthread.php?t=28360
cycdaniel
Dec 17, 2019 10:58 AM
hues10
1G RDX (2007-2012)
Sep 7, 2016 03:47 PM
james357
Feb 13, 2016 02:37 PM
nanos
Nov 12, 2015 08:41 PM
Abe_Froman
Sep 16, 2015 01:27 PM
