URGENT: broken ECT sensor stuck
Old Dec 22, 2018 | 10:20 PM
jonXjon's Avatar
4th Gear
I was installing a new ect sensor in my 05 tsx yesterday and I didn’t realize I bought a faulty sensor to begin with so as I was hand righting the sensor in it snapped off and the other part is stuck in the hole. I’ve removed the fuse box, battery, and intake to make as much room as possible but i still don’t have enough room to work with idk which hoses to remove and how I’m gonna remove the broken peice. I’ve taken pictures to show the amount of space I have to work with and need help knowing what else to remove to make enough space. I dont want to take it a mechanic because they want to charge me $300+ to remove it. Thank you for any help.
Old Dec 25, 2018 | 12:28 PM
TexasHonda's Avatar
I've attached replacement procedure which describes removal. Hopefully nut of ECT body did not break off. If so, an ez out tool will be req'd.
good luck
File Type: pdf
noynek
1G TL (1996-1998)
May 21, 2018 03:05 PM
jgscott
Jul 7, 2005 01:11 PM
TeeL00
2G TL Photograph Gallery
Mar 12, 2001 11:49 PM
