upper display off
Old Aug 17, 2005 | 09:10 AM
JenSRT's Avatar
upper display off
Hey everyone-
I let someone borrow my car and when I got it back, the upper display (where the digital clock is displayed) was turned off (well actually it's just really light and impossible to read). Does anyone know how to turn it back on? My main display is still fine, so it's only the upper display. Any suggestions?
Thanks!
Old Aug 17, 2005 | 09:19 AM
TSX.Fury's Avatar
send me a link to JDM??
ummm idk...
it would affect all your lights but the only thing I can think of is check the brightness adjustment up by the tach
EDIT: or speed-o-meter I forget which side its on.
Old Aug 17, 2005 | 09:22 AM
Dan Martin's Avatar
Photography Nerd
I don't think there's any way you can only adjust the clock section of the center console. This sounds like it's a variation of the HVAC display TSB: https://acurazine.com/forums/showpos...75&postcount=1
Old Aug 17, 2005 | 11:24 AM
Big Teggie's Avatar
7th Gear
Try holding the aux button down.
Old Aug 17, 2005 | 11:48 AM
Dan Martin's Avatar
Photography Nerd
That will affect the entire HVAC display, not just the top clock.
Old Aug 17, 2005 | 01:41 PM
JenSRT's Avatar
Thanks everyone. I called the dealership and they said that this is a common problem with the TSX.
Old Sep 16, 2005 | 09:41 AM
seurat's Avatar
7th Gear
I just encountered the same problem. Was there an easy solution, or will you have to bring it into the dealership? I'd rather not have to replace my audio unit, since my addition of a satellite radio may have voided the warranty.
Old Sep 16, 2005 | 11:00 AM
moda_way's Avatar
Well you have 2 options:
1. Tear out the Sat system and take it in.
2. Leave the Sat in there and they'd have to prove that the Sat system had something to do with the clock light.
Old Sep 16, 2005 | 09:44 PM
achan268888's Avatar
it is the HVAC system. i had my replaced. i have navi. they have to do one piece unit ..1800 usa dollars. oh yes.. under warranty. and i have xtended acura care warranty to 100k. so does it worth it? i paid 895 for it. and restroom happens. i hate unexpected big exepenses.
Old Oct 10, 2005 | 04:28 PM
seurat's Avatar
7th Gear
I chose Option #1: took the car to the shop that originally installed the sat radio and had them rip it out (gently), then took it to the dealer. The warranty was honored, so I paid nothing.
Now I have to bring it back to the other shop to re-install the sat radio. This may have been a blessing in disguise, because I want to see if they can install a splitter to let me plug my ipod into the same aux input that the sat is using. Anybody have any experience with this?
Old Oct 10, 2005 | 04:32 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Yep. You'll need a soudgate aux3, and a switch mounted to allow you to switch between inputs. Try the audio/video section if you have more questions.
ITSJESTER
17
Dec 6, 2018 02:29 AM
adreano17
Sep 29, 2015 08:48 AM
Froid
Sep 27, 2015 06:16 PM
dirleton
Sep 25, 2015 12:25 AM
Brandle34
Sep 23, 2015 07:20 PM
