sunroof rattle issue?
I've been reading some posts about sunroof making a rattling noise when it's closed. Not sure if it's the same problem, but I have a rattling too when ever I go over uneven roads. The only difference is, mine makes the rattle when the sunroof is tilted. Any ideas?
I do believe this thread should go into Problems & Fixes, that aside, a search for "sunroof rattle" came up with this result:
https://acurazine.com/forums/showthr...hlight=sunroof
Furthermore, if you get it when tilted, all the more reason the above should fix it, considering the rubber seal is more "loose", I guess.
Originally Posted by XPLORx4
Problem solved:
I bought some silicone spray lubricant, sprayed it on a towel and wiped the rubber seal around the moonroof while it was tilted up. Lots of black dirt rubbed off! But the creaking sound is now gone.
my parking lot at work hasnt been paved yet and we park on grass and if i have the visor open on the moonroof and drive over the uneven ground, i hear that too. I doubt theres much that could be done, or at least that wouldnt ebe too invasive causing more serious problems.
My previous car, a honda civic, had the same noise when the visor was open.
marcelft
Jul 10, 2018 06:17 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
3GTLOwns
Sep 9, 2015 09:51 PM
