TSX / ABS problem
TSX / ABS problem
2004 TSX, 12,000 miles - ABS appears to have intermittent malfunction. When applying breaks, only immediately after having gone over over slight bump (ie low drainage "curb", or low, speed bumps). Upon pressing the brake pedal, brakes do no engage immediately, car travels at least an extra 15-feet. Only solution has been to reapply the brakes a second time, then they function properly. This only happens at low speeds, and under these described conditions. The bumps are not severe enought to cause the tire to leave the ground. Performed several 40-0MPH tests. ABS works just fine. Also notice periodically on cooler mornings, on first startup only, on first acceleration only, hear the familiar ABS "rattle" for about 0.5 seconds.
Dealer says "all is well". I disagree. Anyone out there seeing something similar?
Thanks.
mariner191
Thanks.
mariner191
I've hit bumps fairly hard under breaking (from 60-0mph as it is right before the turn in to my neighborhood) and got a minimal ABS response, but that is fairly normal as I had it with my 89 BMW too, so I don't see an issue. Just a little trick being played on the ABS sensors.
tsxer
thats kinda funny.....that happened twice to me this morning coming to work....thought i was going to roll out into cross-traffic...... my brakes were pulsing like abs was kicking in.....is there a reset for abs or something?
i have a 2005 tsx and it has happened a couple of times ... when i apply the brakes on small bumps and it doesnt respond right away ... the abs almost pulsate and then right after that the brakes kick in and stop. mine doesnt seem as bad as urs seeing as how i uslually stop right after the bumps ...
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
