TSX '06 Tie-Rod
Old Mar 31, 2009 | 03:51 PM
madrussian190's Avatar
TSX '06 Tie-Rod
I drive a tsx '06 with 57000 miles on it. I ran it up on a curb at about 45 mph, my front tires blew out, and so did my rear. after the body shop repairs, my car rumbles really violently on the road, highway and regular.
I have concluded that the problem is probably cause my tie-rod is bent. can anyone give me step by step instructions on how to replace them?
Thanks.
Old Mar 31, 2009 | 04:26 PM
msmching's Avatar
Ex-King of Pasadena
not sure if u can change it urself tho.. unless you're that good? @@
Old Mar 31, 2009 | 04:28 PM
vthree's Avatar
2006 ASM tsx
is your roof ok?
Old Apr 1, 2009 | 08:12 AM
my roof ? yeah its fine y ?
Old Apr 1, 2009 | 02:33 PM
litesout's Avatar
Oliver!!!
Tie rod is probably bent. Wheel bearings are almost definitely shot too, which would account for the noise. Did the body shop do anything to the rims either? They're probably bent too. For a rumbling noise, I'd start with the wheel bearing and get an alignment. That'll tell you real quick if the tie rods are bent or not.
Old Apr 2, 2009 | 11:39 AM
well... the body shop did replace 3 out of the 4 rims i think, cause the back left or right one wasnt damaged at all. but i took it to the acura dealership to see what they are going to say. since the body shop wasnt acura, it was chevy, i dont think they took a look at the bearings, or the tie rods at all...
so as of now, im waiting for the dealership to tell me whats up, and give me an estimate on the repairs.
Old Apr 2, 2009 | 11:51 AM
npolite's Avatar
Be prepared for a huge cost. If the tie rods are bent, there could also be damage to the inner tie rod too. The wheel bearings are expensive to replace too.
Old Apr 3, 2009 | 08:31 AM
well... the dealership just said that the tie rods arent actually bent at all, and its my 2 back wheels. run me about $664 each.
hopefully that fixes the problem. cause if it doesnt, then im gonna kill someone lol
Old Apr 3, 2009 | 08:51 AM
andrew070489's Avatar
so its your back wheel bearings? ^^
Old Apr 3, 2009 | 08:57 AM
no... not the bearings, but the whole wheel/rim so i need to get 2 of those.
Old Apr 3, 2009 | 04:27 PM
litesout's Avatar
Oliver!!!
But I thought the body shop replaced 3 of them? How could it be the back 2 if at least one of them is brand new?
Old Apr 4, 2009 | 07:54 AM
i think that they replaced the 2 front wheels but 3 tires. they didnt touch the back wheels at all, except for the 1 tire.
Old Apr 4, 2009 | 04:39 PM
nbtx's Avatar
still plays with cars
Work with your insurance company to get the repairs completed. The body shop botched the job, and you shouldn't have to pay beyond your deductible for the car to be back to good.
Old Apr 5, 2009 | 10:22 AM
well, thats exactly what i was planning on doing anyways. but they are also planning on charging me for
any idea if i can do any of these cheaper ?
btw, the induction service i did myself with seafoam.
Old Apr 5, 2009 | 05:34 PM
npolite's Avatar
Brakes are the simplest thing to do and will save you $$$. The pads run about $60. I would recommend you check some DIY on how to do it or get a cheap Haynes manual from Pep-Boys. I doubt they will have a TSX manual but if you find an Accord, the pad instructions are very similar.
Power steering flush isn't usually needed. If you really want, you can get a turkey baster or siphon pump and drain the reservoir twice to get a good amount out of it. (Use only Honda power steering fluid)
The brake fluid should be changed every 3 years. I use Valvoline synthetic as the OEM stuff is too expensive. The on thing to note it you need an expensive piece of Honda equipment to get the ABS going to mix with the fresh fluid. I don't know how much longer the modulators on the newer Honda/Acura products go for, but mine went out on my Integra after 12 years and I didn't start flushing the fluid until year 8. You'll need a helper for this to pump and hold the brake pedal down while you open the drain valve. There are other kits you can buy it you want to do the job yourself too.
If you are motivated, you may want to shell out the money for a factory service manual from www.helminc.com. Good Luck.
tsx_boy
Dec 13, 2019 08:33 PM
mlody
Dec 4, 2019 02:11 PM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
ceb
ILX
Sep 27, 2015 10:56 AM
