Trunk lock
Old Jul 30, 2004 | 08:46 AM
DoCoMo's Avatar
Trunk lock
Folks,
No matter what I do, I can't lock the trunk from the driver side by using the master key in the key slot near the lever that activates the fuel door/trunk release This feature is supposed to help keep you trunk unaccessible when using valet parking, but I can't get it to work. I tried turning the key in both directions with the master key and even though I hear a "click" I can still open the trunk manually by activating the trunk handle above the rear license plate. Am I missing something here?
TSX fan
Old Jul 30, 2004 | 08:48 AM
Helicobacter Pylori's Avatar
I'm allergic to bull
I got the same problem too
Old Jul 30, 2004 | 08:49 AM
dom's Avatar
dom
Have to check that out.
Old Jul 30, 2004 | 09:02 AM
wiz's Avatar
wiz
I think I tried it once and it worked on mine...I'll have to try it again now.
Old Jul 30, 2004 | 09:35 AM
jlukja's Avatar
Isn't there a trunk disable switch somewhere in the glovebox?
Old Jul 30, 2004 | 09:39 AM
slobeatz's Avatar
Littering and.....
Open the glovebox and look up, you'll see a switch to disable the trunk from opening.
Old Jul 30, 2004 | 10:24 AM
jcg878's Avatar
Obnoxious Philadelphian
just get rid of the dead body before you use a valet sheesh
Old Jul 31, 2004 | 09:24 AM
DoCoMo's Avatar
uhm, interesting, could not find a switch in the glovebox. my TSX was built in May '04.
Old Jul 31, 2004 | 10:22 AM
iamhomin's Avatar
04 remembrance
That's funny, it works fine for me..
Old Jul 31, 2004 | 12:18 PM
waTSX's Avatar
Have camera, will travel
The trunk override switch is in the upper left hand corner of the glovebox.
I was able to lock the trunk release lever with the master key, but when I unlocked it, I still couldn't open the trunk with the lever. Weird.
Trunk info is on page 87 of the owners manual, but I couldn't find anything on the glovebox switch.
Johnny
Old Jul 31, 2004 | 12:26 PM
hazuki's Avatar
I got the same problem on my EDM Accord. When I lock it, only the trunk release in the interior is locked.
Old Aug 1, 2004 | 04:58 PM
DoCoMo's Avatar
Johnny
OK, I saw the switch this time, it does override everything else it seems. I don't understand the lock logic then, and how it works with the lock on the floor. I'll take it to the dealership and ask them to check on it.
Old Aug 2, 2004 | 03:02 PM
LSIII's Avatar
The key lock on the floor next to the trunk and gas lever is suppose to lock just the lever. The switch in the glove box only disables the exterior switch. So to completly lock out a valet guy you must do both actions I just listed.
Old Aug 2, 2004 | 10:02 PM
MikeMa's Avatar
No Longer a Poseur
And lock the glovebox, I'd assume...and you'd also only give the Valet the Valet key (can't remember if you guys said the TSX comes with one, but I assume it does), which doesn't have a remote, and won't unlock either the glovebox or the floor lever.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
