Trunk button not working
Old Nov 25, 2008 | 04:07 PM
spoiledkari's Avatar
Boring Teacher
Now that it's been really, really cold here in PA, my trunk button stopped working. I either have to use the button on the keyfob or use the latch on the floor beside the driver's seat. Once the weather warms up, the button works again. Anyone have any suggestions? I really don't want to go all the way to the dealership since it's over an hour away...and they'll probably have to order a part and I'll have to go back.
Old Nov 25, 2008 | 04:40 PM
LuvMyTSX's Avatar
I had a problem with mine earlier this year. Turned out to be a short.
Old Nov 25, 2008 | 05:25 PM
tsx 2 nv's Avatar
ridiculously good looking
did you check the switch in the glovebox?? if you have no idea what i'm talking about, search for "glovebox trunk"
Old Nov 25, 2008 | 05:32 PM
tsx 2 nv's Avatar
err. the search may not work... here:
The trunk override switch is in the upper left hand corner of the glovebox (when you open it).
Old Nov 25, 2008 | 09:31 PM
Boring Teacher
Did they have to replace the switch? Or were they able to fix it some other way?
Old Nov 25, 2008 | 09:33 PM
Boring Teacher
Yeah, I actually checked that first. This problem comes and goes and it seems to be weather related.
Thanks for the suggestion!
Old Nov 26, 2008 | 02:44 AM
s001y's Avatar
If at all weather related, try the following :
Take out the switch and see if there is any residue of oil etc and wipe it off. Could also use a hairdryer and blow hot air and wipe off. Check the contacts as when cold, some oils form a film when hardened.
Or else doe not work, get a replacement switch to be send to you by post... 1hr drive for a faulty switch ain't worth it...
Old Nov 26, 2008 | 07:42 AM
LuvMyTSX's Avatar
I'll have to find the invoice when I get home. At least it was covered under warranty and didn't cost me anything.
mada51589
Jan 9, 2025 04:40 PM
TLDude876
Dec 28, 2016 03:18 PM
acurajj
Sep 19, 2015 03:47 PM
PortlandRL
Sep 14, 2015 12:01 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
