Tighten Gas Cap
Tighten Gas Cap
I have a 2006 TSX and just got this message "Tighten Gas Cap". The dealer says to wait for 3 days while it cycles through. It's been 3 days. Anyone else have this problem. Looks like its' off to the dealer service department I go.
how many times have you driven your car in the 3 days? It should go away after 3-4 times driven after you tightened your gas cap. You did tighten it, right?
[QUOTE=jlukja]how many times have you driven your car in the 3 days? It should go away after 3-4 times driven after you tightened your gas cap. You did tighten it, right? [/QUOTE
I've driven it 4 times in 3 days after tightening the gas cap. Dealer won't do warranty work on saturday so I have to take a day off to let them screw with it.]
It should have gone away. You can clear it yourself by resetting the ECU (disconnect the battery leads for 5 min.) and see if it comes back. Just make sure you have the radio and navi codes before you do that. Or, just let the dealer deal with it. Good Luck.
Looking at the '15 TLX
Originally Posted by russduck
Clicked the gas cap 3 times and that cleared the message
