Strange Power Window Switch Issue
Old Aug 29, 2016 | 10:31 PM
haniforama's Avatar
I have an '07 TSX with approx 220kms on it.
All of a sudden, the left-rear window switch from the driver's master control would allow the window to lower but not raise. The left-rear door switch itself works perfectly fine - as in I can raise and lower the window normally without issue. When I use the driver's switch though, it goes down but not back up.
I thought ok: it must be the master switch so I went to a local wrecking yard and picked one up for $50. I swapped it in and tested it but the exact same symptoms remained - so no change.
Any ideas? Could it be the rear switch or perhaps wiring? Fuses all look ok and I didn't see any loose wiring.
Any help is appreciated.
Thanks.
Old Aug 30, 2016 | 09:21 PM
haniforama's Avatar
Some more information - on the assumption that the master switch is fine, I swapped the rear left and right switches hoping the problem would follow the switch but it did not. It stayed on the rear-left side. Again the rear switch working perfectly while the master was able to lower the window but not raise it. I don't hear anything when I try to raise it from the master switch. I tried the wrecker replacement again for fun and it didn't change anything.
So I'm left with the wiring between the master switch and the left-rear door as the likely cause of the fault. Any other suggestions before I break out the multi-meter?
Old Sep 1, 2016 | 06:48 AM
mrgold35's Avatar
mrgold35
My RDX did something similar with the driver side control for front passenger not working while the front passenger controls where working fine. There was a reset procedure and that worked for my RDX. I think it happened around the same time I replaced my alternator; but, didn't notice for a while since the RDX sees mostly commuter duties with just me.
I found this for the TSX: http://www.dormanproducts.com/digita...748-046_TN.PDF
The PDF said to perform the reset procedure if any of the following was done:
• Disconnecting the battery.
• Removing the No.79 (20 A) fuse in the under-hood subfuse box.
• Disconnecting the 18P connector from the power window control unit.
• Removing the window regulator, glass or glass run channel.
• Disconnecting the driver’s door wire harness.
You can also try the procedure in this thread on post #6: https://acurazine.com/forums/second-...cedure-700654/
dubz ASPEC
Jun 3, 2025 08:48 PM
gavriil
Jan 6, 2025 01:04 PM
rcoz89117
4G TL Problems & Fixes
Sep 20, 2016 04:56 AM
A4orce84
Aug 3, 2016 12:45 PM
vito_ip14
Jun 13, 2016 04:29 PM
