steering wheel shakes when braking
Old Feb 4, 2008 | 09:17 AM
rhainda's Avatar
Question steering wheel shakes when braking
I have observed that occasionally the steering wheel on my 05 TXS shakes/shudders when braking. I dont think it is a wheel alignment or balancing issue since I just got 4 new tires less than a month ago. I also had the dealership check the brakes on the car at my last service and they said i could go on for another 20K on those brakes.
I read something about brake shudder comebacks in the october service bulletin. I am not sure how it applies to my situation.
Any suggestions will be helpful.
Thanks,
Ravi
Old Feb 4, 2008 | 09:25 AM
LukeaTron's Avatar
Did they check the run out on the rotors? Sounds like rotor warpage or a build up of pad material on the disc. It's a common problem and there tons and tons of threads on the topic. Try searching for "brakes shaking".
Old Feb 4, 2008 | 10:41 AM
PACman's Avatar
Welcome to 2004. LukeaTron basically covered it.
Old Feb 4, 2008 | 12:05 PM
CCColtsicehockey's Avatar
yup warped rotors sucks but it happens. see if you dealer can mill them down and fix it. if not you will need new rotors which always sucks.
Old Feb 4, 2008 | 12:56 PM
Simba91102's Avatar
Old Guy
I agree with the warped rotor diagnosis, but I wouldn't waste your time and or money with turning the rotors. Just replace them; they're cheap enough. I just replaced all 4 of them on my 05 and it the cured the problem. You can easily find 4 rotors for around $200 and replace them yourself; it's a fairly easy job with hand tools. Plenty of threads here on how to do it too.
Old Feb 4, 2008 | 01:22 PM
jlukja's Avatar
I'm going to refer you to this thread:
https://acurazine.com/forums/showthread.php?t=27657
Have a good read of that thread and if you have any follow up questions then please post them in that thread. I'm closing this thread since we have a number of them going on this very topic.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
IIDXholic
Sep 19, 2015 10:18 AM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
