steering wheel shakes when braking
I have observed that occasionally the steering wheel on my 05 TXS shakes/shudders when braking. I dont think it is a wheel alignment or balancing issue since I just got 4 new tires less than a month ago. I also had the dealership check the brakes on the car at my last service and they said i could go on for another 20K on those brakes.
I read something about brake shudder comebacks in the october service bulletin. I am not sure how it applies to my situation.
Any suggestions will be helpful.
Thanks,
Ravi
Thanks,
Ravi
Did they check the run out on the rotors? Sounds like rotor warpage or a build up of pad material on the disc. It's a common problem and there tons and tons of threads on the topic. Try searching for "brakes shaking".
Received 3,860 Likes
yup warped rotors sucks but it happens. see if you dealer can mill them down and fix it. if not you will need new rotors which always sucks.
I'm going to refer you to this thread:
https://acurazine.com/forums/showthread.php?t=27657
Have a good read of that thread and if you have any follow up questions then please post them in that thread. I'm closing this thread since we have a number of them going on this very topic.
rockyboy
08-04-2024 10:35 AM
