Stabilizer Link Not Positioned Correctly or Crooked?
Please help! Can you look at these pictures I took of my Driver Side and Passenger Side Stabilizer Link? The driver side looks more crooked then the passenger side. Where I circled in blue on the driver side----it looks like it's not attached correctly on the bottom and pulling away. When I compare it to the passenger side---it's looks straight and less crooked. Can someone do me a favor and crawl underneath their TSX behind the wheel and look up with a flashlight to see if it looks the same? Is this normal?
Thank you so much!
Shawn
Links to Photos Below:
Driver Side:
Passenger Side:
Thanks again!
Thank you so much!
Shawn
Driver Side:
Passenger Side:
Thanks again!
Looks to me that the sway bar is shifted slightly to the right. Shouldn't really be any cause for concern. Has the car ever had any suspension repairs done? Usually see this on cars that have had one side of the suspension banged into something, but also possible it just wasn't perfectly centered when the car was assembled. Probably not very easy to correct without lowering the front subframe down, because as I recall the sway bar mount bolts are not easily accessible. If you can loosen the sway bar mounts, the sway bar should fairly easily slide side to side.
Thank you so much!
Shawn
Driver Side:
Passenger Side:
Thanks again!
Thank you so much!
Shawn
Driver Side:
Passenger Side:
Thanks again!
I had that when I first installed my sway bar. See if you can wiggle it and it should come loose...
Originally Posted by evil_acura
not to hijack this thread but anyone know how to take that exact part out? (the part u have circled in your pics)
I tried using the hex key and stripped it away.
evil_acura: since you are looking to change this part, can you at least tell me if the driver side looks the same as mine, please?
I only noticed mine was broken casue my steering became different.
Driving was normal, only noticed it at uneven road wears where it felt like the wheel (on the broken stabilizer link) was trying to move with the road unevenness. hope that helps a lil
MrHeeltoe
20
Feb 23, 2023 01:54 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
