Squeeling noise from engine area at idle
Recently I've been noticing a squeeling noise from the front lower passenger's side engine area, around where all the drive belts are, and sounds like a belt slipping. Noise is relatively loud outside the car, and can be traced from around the lower bumper area on the passenter's side. However, it only occurs when the car is first started and warming up at idle. Once the car is warmed up, the noise is gone. Any ideas what this could be?
Car is just out of warranty and I strated getting this noise..
Originally Posted by supraken
I haven't really looked carefully, but I thought the alternator, AC, power steering, etc were on separate belts. So it's all driven by one single belt?
Rep'n Taxbrain.com
Also try turning the A/C on and off to see if that changes the sound. (The A/C compressor also runs on the same belt.)
You can also try turning your wheel on the way left or right. (Power steering also is on the same belt.)
There are cutaway photos of the TSX engine on my webpage that show the drive belts and tensioner
Ride and Drive Review Page
Originally Posted by poltergeist
To determine if this is the source of your noise......with the engine at idle making the noise, spray just a little WD40 (too much and it just gets flung all over) onto the inside of the belt with the little red nozzle.
![what](https://acurazine.com/forums/images/smilies/what.gif)
I might suggest running soap over both sides of the belt maybe a few inches long on both sides. Don't overdo it.
Mike Bertram
09-10-2015 09:27 AM
