Squeeking when turning
Old Jan 11, 2011 | 09:58 PM
quikws6's Avatar
Question Squeeking when turning
Hi,
My 05 TSX now has a squeek while turning. It is actually very loud, sounds like metal on metal. Problem is, it seems to go away?
Also seems to happen more when it is snowing or very cold.
Sounds like a an issue, had it towed to a shop (was worried something was broke), then it didnt make the noise.
Drove the car about 40 min the next day and came back, very loud. Worried about driving it again.
Anyone have this issue, or have ideas of what it may be?
I just had new tires, an alignment and ball joint replaced about 4 weeks ago. Hopeing its not Rack and Pinion.
Thanks for the help.
Old Jan 12, 2011 | 09:29 AM
Strieter's Avatar
try checking the metal dust shield behind the rotor, may be rubbing on the rotor.
Old Feb 2, 2011 | 08:21 PM
Will1688's Avatar
did you figure out what the problem is? a friend is having the same problem -- checked the brakes/pads and they all seemed fine also
Old Sep 8, 2011 | 03:05 PM
nigelboyne's Avatar
i am haveing same problem at low speed and turning the noise is unreal sounds like the spring is broken checked everything cant seem to find problem greased up joints goes away temp then back with vengence
Old Sep 11, 2011 | 12:43 PM
nigelboyne's Avatar
looks like a bottom ball joint, your problem might be drop links
Old Sep 12, 2011 | 04:34 PM
nigelboyne's Avatar
small bit of play in bottom ball joint hopefully get new one in tommorow
Old Sep 13, 2011 | 07:02 AM
miner's Avatar
Possibly a bad rack - I had same symptoms on my '08 and rack was replaced.
Old Sep 13, 2011 | 07:11 PM
Pocketman's Avatar
My steering squeaked, when stationary or at very slow speed. Especially noticeable when first starting out. Dealer lubricated the steering shaft today and I've not noticed the sound. Will see what a few days produces.
Old Sep 22, 2011 | 12:53 PM
nigelboyne's Avatar
thats how mine started but it was bottom ball joint,and what a job to get done, the cv joint would not come out of the hub had to send the whole lot to a 60ton presser which got it out but they damaged the threads on the joint, so of to machine shop to regrove fix up the thread to take the nut again,back to garage to put it all back on car, and the presser had bent one of the lugs that bolts up the caliper of the brakes, back to the ENGINEIER and the presser had to heat up the metal and bend it back, car has been up on the ramp 4 days id have been better of and cheaper to replace the cv joint and hub new from honda.still 250k its first time car has been of the road.
IBankMouse
Jun 13, 2020 12:53 PM
SidhuSaaB
May 30, 2020 12:40 AM
LoneRonin
Jan 4, 2016 01:03 AM
Dman00tl
2G TL Photograph Gallery
Sep 25, 2015 10:34 AM
Brandle34
Sep 23, 2015 07:20 PM
