service light
service light
guys , my service light just went on, i have about 3,500 miles on the car.
I found this here and was just wondering where the select/reset button is?
Thanks guys.
Vic
Originally Posted by Tireguy
put key in ignition, press and hold the select/reset button turn the key to the "on" position, continue to hold the select/reset button until the light flashes and goes out(shouldn't take more then 10 seconds).
Thanks guys.
Vic
Why would reset the light instead of just having it serviced?
My light just came on two, at about 4000 miles, but I still have 15% of my oil life left -- it's just an advisory at this point. I wouldn't worry about getting it done until it drops to 5%.
If you click the "I" button on your steering wheel, the message will go away until the next time you start your car.
It's really not a good idea to clear the service indicator without having the corresponding service done -- that defeats the entire purpose of the system.
1. Open glovebox
2. Remove manual
3. Read
Its all covered in your car's manual. Its right in the section about the maintenance minder system and oil changes, and what to do if you change your own oil or have a non-dealer do it.
The steps you posted above refer to resetting the automatic 10k mile flashing maintenance light, vs the maintenance minder system in the MID. Again, its all in the manual. It really is worth it to spend an hour one night and just read the whole book.
put the key in the ignition, turn to the on position, and hold the "select/reset" button on the steering wheel for approx. 10 seconds. The MID will now show you the service warning "a" which is oil/filter tire rotation, and general check up on brakes etc... Nothing you can't get done at a local oil change place or what you can't do yourself. At the bottom of the MID you will see an option that allows you to reset the warning. Press the "I" button until reset is selected and then hit the "sel/reset" button and all gone. Remember you have 15% oil life left according to the MID, so get your oil changed within the next 1000 miles.
If this is your first oil change since you took delivery use standard oil, same with the second oil change then you can switch to full synthetic or a blend if you choose.
Hope that answers your question
what is there to service? the oil & filter was changed 600 miles ago
Sarcasm aside, your owner's manual contains the complete instructions for resetting the indicator.
Also, your owner's manual specifically told you not to change the oil early, either.
I'm a Fucktard for asking a question? jerkoff.
fucktard----->:gheyfight:
Then again that would have required either a search on this board or a long walk to the gararge.
mada51589
Jan 9, 2025 04:40 PM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
