Rusted exhaust tip bolts
Old Jun 15, 2004 | 02:21 PM
xizor's Avatar
Bye TSX, hello domestic?
Just as a tip if anyone needs help in the future:
When installing my OEM kit I was removing the flange bolts that hold the exhaust tips in and busted the head off the bolt. The bolt head and the hole in the tip were rusted pretty bad and didn't want to come off. I highly suggest putting some WD40 on there before you take them off so you don't end up like me.
I headed out to home depot today and found a perfect fit, in case anyone ever has this problem here's what the packaging says:
Hex Bolt (Pack of 2)
6mm x 10 x 16mm
UPC 0-30699-35768-0
Old Jun 15, 2004 | 08:11 PM
JTso's Avatar
I've always used anti-seize on any bolts/threads that exposed to high temp and possible of rusting or hard to remove. I use it on spark plugs, exhaust bolts, wheel studs, manifold mounting studs. etc.
Jul 16, 2017 07:33 AM
lanechanger
Oct 13, 2015 10:56 AM
joflewbyu2
Oct 8, 2015 11:16 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
