Rubber undercarriage rustproofing
Hey guys,
I tried searching for this but all I found was rustproofing from the factory.
A guy I work with bought cans of that rubber spray in an aerosol can from walmart and coated the entire bottom of his car in prep for winter. Anyone ever try anything like that on our cars? Or a different suggestion?
I live in PA and we get decent winters here sometimes but they love to salt the roads. I would like to minimize the rust lol
Thanks for help/suggestions.
John
John
Are you talking about plasti dip? I live in Iowa and don't worry much about the salt. Just make sure you wash it often. I have a 97 accord that has no rust. My suspension components get rusty and that's about it. Here's a tip for you. If you do your own suspension work try using anti-seize when putting things back together. I even use it on my lug nuts.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
The Sicilian
I've always used this product for all my cars. So far so good on all of them.
Permatex® Undercoating
Protects fenders, frames, fuel tanks, door panels, rocker panels, hoods and firewalls against moisture, road salt and corrosion. Won’t sag or drip. Sound-proofs and insulates. Body shop proven. Level 3*
Suggested Applications: Wheel wells, rocker panels, frames and underbody, body repairs, rust holes, tree pruning, driveway cracks, minor roof repairs, post preserver.
![](http://www.permatex.com/images/img_topleft.gif)
![](http://www.permatex.com/images/spacer.gif)
![](http://www.permatex.com/images/DisplayImage.asp?210|/images/ProductPhotos/80072.jpg)
[/quote]
It almost has as many uses as ductape!![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Anyways,
What all have you used it on? The whole undercarriage? Any pictures?
Thanks,
John
![](http://www.permatex.com/images/DisplayImage.asp?210%7C/images/ProductPhotos/80072.jpg)
Anyways,
Thanks,
John
Where can you pick some of this up?
Someone stole "My Garage"
I would stay away from the rubberized undercoating. All it really does is mask what nastiness is occurring between it and the metal. It traps in moisture, and that means RUST. Sure, it will protect the undercarriage from rocks and rock salt chipping the protective coating from the factory, but it does nothing to prevent and may actually expedite further rusting.
Get a quality oil spray that will creep into tiny crevices. Rust Check (Canadian I believe), Krown (Canadian also), etc... are all thin mineral-oil based sprays that WILL protect from salt and water damage by forming a protective barrier that repels water away from the metal, unlike rubberized undercoatings which trap water against the metal.
thanks again
John
You want to AVOID the "no drip" stuff, as the no-drip also means no-creep, meaning it won't get into the tiny voids between welds, etc. Just don't park in your driveway for a few days after getting it done.
You can try searching on http://www.eastwood.com/. They have a bunch of products that can help with undercoating. That stuff you get at autozone doesn't work.
http://www.eastwood.com/ew-anti-rust...zle-black.html
SidhuSaaB
05-30-2020 12:40 AM
cycdaniel
12-17-2019 10:58 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
acura, advertisement, car, flex, mdx, panel, pittsburgh, proofing, protect, road, rocker, rubberized, rust, salt, seal, undercarriage, water, work
