ROUGH IDLE- Please Help!
When car is in drive/ gear and I am on the brake, the idle is EXTREMELY ROUGH, the whole front of the car vibrates, and the enguine makes an awful noise like it is about to quit.
I have taken it in to dealers 3 times & this is what they have done:
1) Replaced 2 motor mounts and did a throttle body cleaning
2) Installed new power steering hose
3) Neutralized engine mounts & performed idol learn procedure
After each time the rough idle & vibrations have gotten worse. Please tell me if you have had or have this problem and how you fixed it. I'm at the end of my rope!
If you have called Acura (800.382.2238) about it, or have a case manager please let me know.
Case
By the way if you are having the same problem feel free to message me directly...I am looking to get all the people I can to bring it to Acura, and if they don't fix it then I'm going to the better business bureau!
Sounded like the dealer has attempted to fix your problem more than once, but failed to fix it correctly. Bring it back, tell them to fix it right, and see what they tell you.
Corporate has even tried telling me this is normal wear and tear...I said at 18000 miles this car goes to crap...I don't believe that...so that's why I'm on here asking for help before I go insane!
I have taken it back four times now, even got corporate involved. It seems the dealer (I've been to 2 different ones) realized there is something wrong but can't figure out exactly what it is.
So of course corporate is trying to say this is normal...how is it normal for this car to start doing something at 18000 miles all of the sudden that it never did. And if its normal why have they worked on it 3 times.
I'm asking for help...anyone that's fixed this problem please tell me how & what!
Yep they've been doing everything under warranty...I'm thinking its a lemon too...but trying to get Acura to admit that is like pulling teeth or something!
They would rather tell you its normal, nothing is wrong, or its your problem rather than do anything.
That's why I got on this forum to ask desperately for help how to fix the car, or what I can do.
I don't think they are repairing the right thing......you said that the engine is making an awful noise and they went to change the motor mounts??? The throttle body cleaning is okay, but at such a low milege??? The power steering hose was replaced because of a recall campaign and has nothing to do with the rough idling. Have them check the engine itself, including all air hoses, etc. or get second opinion.
El Cunado
My BMW had an idling issue and it went away after cleaning the Idle Control Valve. It's basically just a valve that lets a small amount of air into the intake manifold when the throttle is closed (because you aren't using it when sitting at idle). Now, I'm not sure if TSX's have ICVs, but if they do, yours could be dirty and need cleaning/replacing. This might be useful to you before I get home much later and am able to check my '04-'05 TSX Service Manual.
I thought that cleaning the idle control valve was part of the throttle body cleaning?
El Cunado
There are a lot of sensors in the engine itself. It sounds like it could be a bad knock sensor. I'd try the idle air control valve first.
El Cunado
I don't see anything like an idle control valve. It makes sense in a way because I would think it would have been on their list of things they tried cleaning/repairing/replacing to get it working correctly.
Perhaps it's one of the many sensors in and around the engine. I think it's feasible that a bad sensor could cause the roughness but it would probably throw an error code as well.
Take it back to the dealer, get a loaner and tell them your not coming back until problem is fixed 100%. end of story.
I have tried this on five occasions now...to the point that they are telling me they are not acknowledging a problem, and it is normal.
I even went for a test drive today, which I posted about. I'm being lied to at this point...I think they don't want to admit there is a problem because they can't figure out what the problem is.
I'm really frustrated now and don't know what to do.
Took a test drive with the dealer service manager & district manager today...during the ride the district mgr kept asking the service mgr if he had his foot ALL the way on the brake, which he did...and also if the service mgr had replaced the air compressor...which he had not.
But after the ride he would not look at the car, or test or check anything. Refused to say there was anything wrong, saying it was normal...but could not explain to me if this was normal and there wasn't anything wrong then why had it only started it at 17000 miles, and why they had worked on it 3 times.
He also offered to extend my warranty for free, and told me if I had it fixed else where that they would pay me back if I signed something saying the problem was fixed.
Anyone else out there think I'm being lied to! Or have any suggestions up to this point how to deal with this, or know contacts for me.
El Cunado
Thank you! I just called the Better Business Bureau- Auto...is the lemon law better? Should I do both at the same time?
El Cunado
Both. Use the BBB to discuss the individual dealer(s) that have worked on your car.
Lemon Law attorneys could give you an opinion (usually for free since they're always looking for new cases) about your situation. If they think you have an honest case, they'll probably want to get involved.
I think I would also send a certified letter to the Acura zone office, documenting everything and everyone involved. That is BS of them telling you to take it elsewhere to have it fixed. Sounds like you have some pretty $hitty dealers in so. CA.
What is the Acura zone office? Is that different then Acura corporate/ customer relation & case managers? Because I went to corporate & got a case manager after I had it worked on 3 times. But they keep telling me to take it back to the dealer & have the district manager look at it.
So like I said it seems they don't want to "admit" there is a problem, like I'm being lied to.
El Cunado
I really think you should look into a consumer-type legal case. I'm no lawyer, but I think you have a case, especially if you've kept good record.
Make sure you keep taking note of everyone you talk to, their position, what they say, and the result of doing what they say.
Oh I have times, dates, names & wrote down notes on the convos. I have ALL the paperwork on anything that's ever been done to my car...even every oil changed.
I'm like a dog with a bone...I don't just give in, and I'm the type of girl that can be your best friend or worst enemy...
But ultimately I've owned Honda made cars my whole life & they've always been awesome...so I'm disappointed now with the company...I mean just admit its a lemon, or that you can't figure it out and do something about it.
Like I said before, get a loaner and don't pick your car up until it is fixed 100%. also go have discussion with the dealership owner.
What did the district manager do? Get his boss involved. Raise hell until you get satisfaction.
user title goes here
lets not start uneeded comotion here. sometimes, no wait, always you'll get farther with dealers when faced with situations like this if you remain calm and not some crazy person who feels the dealer are at your feet. you did not purchase a lambo or a rolls royce.
as far as your problems, i feel your dealer should be honest with you and not just throw parts at this car. that will burn them in the long run.
WHEN "ROUGH IDLE" OCCURS,
...is the car in park or neutral?
...does the rough idle occur upon cold starts? or every single start up. THIS MEANS AFTER YOU DRIVE 10 MILES TO YOUR WALMART, 30MINS OF SHOPPING PASSES, AND YOU START YOUR CAR AGAIN IT IDLES ROUGH!!!!
...when idle occurs note the following (a/c on/off,lights on/off,radio etc.) these are known as loads.
...i have more but ill wait for your answers.
it sucks you as an owner has to diagnose your own car. but based on your thread bumping, i can gather you are at the point where anything is worth it.
thanks
thanks
Only when I did that...the dealership started to change what they were saying. Before they admitted my car was worse than other cars they tested it against and there was a problem. But after I got a case mgr, the dealership started saying it was normal and they won't admit there is a problem.
So since the test drive yesterday I called the Better Business Bureau.
But I'm still hoping there might have been someone that's had this problem and found a solution or a fix.
thanks
thanks
I do think I have a faulty AC compressor because now I've noticed it make the rpm's erratic, but that's new.
Since it happens during the day too, the headlights aren't an issue. And I've been driving with the radio off just to see if I notice anything to help figure out the issue.
Yes I am at the point where anything is worth it! Both dealers I had taken it to had admitted it was rougher than it should be, and when compared to other TSX's it was worse. But after they tried fixing it 3 times I made the mistake of calling corporate & getting a case mgr, thinking that would help the dealer figure out what was wrong faster.
But since I've gotten them involved everyone has started telling me this is "normal"...but no one can explain if it was normal why did it start at 17,000 miles, and why has the dealership worked on it 3 times if it was normal.
So I'm at my witts end because I feel, now, like I'm being lied to and no one was helping me but just trying to get me to go away.
so only when brakes are being applied this rough idle occurs?
and for the record the car is completely stopped at a light/sign. right?
try this. when the rough idle occurs immedialty place shifter lever in neutral. now try this with a/c on and a/c off. you may have to do this more than twice to really get a feel for it.
does the rough idle differ between a/c on or off, does it differ in neautral or in d
let us know.
let us know.
Even though the car is under warranty, I'd probably think about taking it to a really good private mechanic at this point, at the very least to get it diagnosed and then maybe take it back to the dealer and have them do the repairs. Hopefully *someone* can figure it out for you. You'd think the dealership would be the best place because they of all places should know the car, but whatever. Bottom line is you need it fixed.
had my dad (he's a mechanic for 15+yr) check out my ac due to numerous AC failure reported in the 04 model. And he discovered that the erratic rpm when ac is on is due to ac system is plugged up by mostlikely from the ac dryer thats connected next to the condenser.
rough idle with ac on is possibly due to bad bearing of the ac which eventually lead to pieces of the compressor enteriing the ac system. the dryer acts as evaporator of moisture and filters out contaminate. Once it's clogged/busted .. it possilby will cause the eratic rpm. compressor turns on to get the ac going .. but it's clogged with enough pressure, the ac turns off.
On my car, it repeats this cycle every minute.
Try this .. run your car, turn on the ac system via the speed fan button, then turn off the ac via ac button till it shows "AC Off" on the display. This should turn off the ac but keep the blower to stay on giving your a blast of air, just like a normal fan would do if it's on.
See if your idle problem persist. If so .. have the dealer check the ac system. if not .. i'm clueless atm.
good point^^. honestly after op said he has been to several dealers, i would imagine they focused some attention to his a/c compressor. yes we all know on a four banger any extra load added(such as the compressor engaging) will slightly decrease rpms and well we know the pcm ups the idle speed to compensate blah blahblah.
yes one would think this was looked into, but who knows, i have a feeling the op might figure this out without the help of his local dealer. keep us updated
Yeah but the erratic rpm twitching & not settling just started. So I didn't think this whole time it could be just because of a bad ac compressor.
I am thinking of taking it to an outside dealer and paying them to tell me what is wrong. Then taking it back to the dealer and saying this is the problem, please fix it!
I'm taking it to a mechanic that works on my friend's '06 TSX, and asking him to help me figure out what's wrong. Maybe then I can take it to the dealer and say this is what's wrong, please fix it now.
I'll let you know what they tell me is wrong, so the mystery can be solved!
