Replace CAT heat shield?
Old Jan 26, 2015 | 09:14 PM
Lone Starr's Avatar
'06 TSX 6MT
I was troubleshooting a LAF sensor code, when I noticed the heat shield around the CAT was rusted badly and when I tapped it, it broke! (there was 1 bolt holding strong, but the rest was held by <1mm of rust).
The question is- is it worth $70 to replace it?
WWBBD?
Old Jan 26, 2015 | 09:21 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Short answer is no.
Old Jan 27, 2015 | 05:21 AM
Braz60's Avatar
Heat Shield
Had the same problem on my 2006 TSX bolts rusted through and would rattle so what I did was buy 2 adjustable metal straps (clamps) that you tighten with a screw works great!
Old Jan 27, 2015 | 08:34 AM
NBP04TL4ME's Avatar
This is relatively common across most manufacturers. Most shops and mechanics will simply remove when investigating rattling noises. You could certainly try Braz's idea.
Old Jan 27, 2015 | 10:39 AM
npolite's Avatar
Most dealerships use the clamps instead of replacing the shield. The clamps will hold the shield better and most likely for a longer period of time. I have gone through 3 replacements of the heat shields on our 99 Accord before starting to use the clamps.
Old Jan 27, 2015 | 05:59 PM
Simba91102's Avatar
Old Guy
WWBBD?
New shields (it's 2 piece) or clamps? Is your car a semi-premium sport luxury sedan (though older), or a Chevy Cavalier? You decide. Let your answer to the second question guide you to an answer for the first.
cycdaniel
Dec 17, 2019 10:58 AM
Joseph Stansbury
34
Dec 4, 2015 01:57 PM
nanos
Nov 12, 2015 08:41 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
truonghthe
Sep 7, 2015 11:17 PM
