Removing both front seats??
Old Mar 11, 2009 | 02:36 PM
WFC's Avatar
WFC
I apologize if there is information already posted on this topic, but I could not locate any. I would like to remove both front seats to get a good vacuum and cleaning of the carpet, since there is minimal room to get any type of cleaning device in there. Is there anything I need to be cautious of attempting this? Besides disconnecting the battery. Any torque specs on reinstalling the bolts? Any info would be greatly appreciated, thanks.
Old Mar 12, 2009 | 08:01 AM
curls's Avatar
Someone stole "My Garage"
Just removed and reinstalled my drivers' seat on Sunday, and it was simple. Remove the two plastic covers near the floor to expose the rear pair of bolts. These just kinda pry off and slide backwards. Slide seat fully forwards and up as high as possible. Remove two rear bolts. Then slide seat fully backwards and remove front two bolts. Tilt seat back forwards to make it easier to remove from the car. Disconnect negative cable from battery now. Tile the entire seat backwards and disconnect the wiring harnesses for the SRS airbags. Remove seat (I recommend putting a towel on your doorsill so it prevents scratches, just in case!). You will need two people to full remove the seat, but if you are just vacuuming, you might be able to just disconnect the 4 bolts and tilt the seat as required, not worrying about disconnecting the battery and the airbag wiring.
Torque for reinstalling the 4 bolts is 25 ft-lbs, starting at front-right bolt and working counterclockwise to end at the rear right bolt.
Old Mar 12, 2009 | 09:25 AM
xjohnkdoex's Avatar
where is my garage?!
i have to do this some day. i'm pretty sure there is a cap for a baby formula bottle and mutiple quarters hiding underneath my seats. i can never get them out from the openings.
Old Mar 12, 2009 | 10:43 AM
kvelez07's Avatar
I usually just slide the seats all the way forward, and then all the way back...and i've never had an issue getting the vacuum hose in there....those are just my 2 cents...
Old Mar 12, 2009 | 12:49 PM
curls's Avatar
LOL I think I made about $3.35 on Sunday -- there were 3 $1 coins, a quarter, and two nickels. My daughter put them in her piggy bank and asked if there were more. LOL!
Old Sep 14, 2017 | 01:37 PM
wrentham636's Avatar
9th Gear
Just my two cents regarding avoiding airbag deployment. If you're being careful enough to disconnect battery, also wait 10-15 minutes as well. "Some" systems store a small amount of power and the delay will let that bleed off. Better that bleed than the other kind...
Feb 25, 2020 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
08 NBP TL
Sep 8, 2015 08:49 PM
truonghthe
Sep 7, 2015 11:17 PM
