Rear Sway Bar Link TSB (98-05 Accord)
#41
Originally Posted by joerockt
![](http://photos.imageevent.com/astroboy/webstuff/smilies/ohsnap1.gif)
Hey, I never commited to this latest meet!
![](http://photos.imageevent.com/astroboy/webstuff/smilies/spankie.gif)
Well meet soon
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
I also noticed the new smileys.
jlukja, who can't make the 6/4 meet either.
#43
Tech
Back to the topic....LOL
Going to Honda this week to purchase the new endlinks. Expect a followup from me real soon.
Also, Im gonna see if the new 05 TSX's already come from the factory with the new links. Since they put a thicker sway in the back of the 05's, they MIGHT have changed the links to the new beefier ones.
#44
All the current sites I've checked so far still list the current part numbers. That's not to say they haven't already included them in the manuf. line, but I doubt.
Also, don't forget to order the kit number from the TSB. Please post pics of the new end links next to the old.
#45
Dude, I've tried many things with those bolts. I've come to the conslusion that the bar isnt sitting flush with the end link, thus causing shifting, thus causing the clanking.
And I think the reason why its not sitting flush is because its in upside down...has to be...
I'll find out this weekend...
#46
Bye TSX, hello domestic?
#47
My Garage
Originally Posted by xizor
what's the size of the 05? didn't know they changed it
http://www.acura.com/models/model_sp...asp?module=tsx
#49
Received 3,833 Likes
has anyone fixed this problem cause I had the same noise and I tightened the one endlink and the noise went away for like 2 weeks. Now the noise is back but I cant make the bolt any tighter so something is wrong. I dont have a sway bar I just have my car lowered on tein flex coilovers.
#50
Tech
The 04 TSX have 26.5mm front and 14mm rear bar.
The 05 TSX have 25.4mm front and 15mm rear bar.
#51
Tech
I also tried a few Honda dealerships around this area, and it seems that the part # isnt even showing up in their parts system. Still searchin though...............
#52
2004 front swaybar
![](http://www.tsobad.com/jtso/Images/Swaybar/2004%20F.jpg)
2005 front sway bar
![](http://www.tsobad.com/jtso/Images/Swaybar/2005%20F.jpg)
2004 rear swaybar
![](http://www.tsobad.com/jtso/Images/Swaybar/2004%20R.jpg)
2005 rear swaybar
![](http://www.tsobad.com/jtso/Images/Swaybar/2005%20R.jpg)
#53
Tech
Originally Posted by JTso
Not sure where you got your info but here are the actual part numbers. Note the size in the p/n and year of the TSX.
These specs are directly from Acura's website and 04 and 05 brochures.
04 TSX Specs
05 TSX Specs
#54
#55
#56
Tech
Finally found a Honda dealership that was able to find the new revised links, and to my suprise, they actually had one set instock.
They retail for about $112 but since I work at a dealership myself, my cost was $84 and some change
Just waiting for monday till im back at work to install them.
#57
![Ponder](https://acurazine.com/forums/images/smilies/ponder.gif)
#58
Tech
Finally the new endlinks are installed. Theres not much difference between the endlinks except for the fact that the updated endlinks are beefier, about 1mm thicker than the factory TSX endlinks.
I'll try to post some pictures when I find the time to get them on my computer.
#59
Got Milk???
Does that Honda TSB on the endlink also apply on our TSX? I want to take my car in and ask them to replace the right side endlink with the beefier one. That way both sides will have new endlinks. If that Honda TSB also applies to our tsx, then I can just tell my dealer that they did not complete the job, any suggestions?
-KC
-KC
#60
Tech
-KC
-KC
#63
I haven't investigated the end links yet but found something else
that may be causing the noise on bumps. The comptech frame mount
bushings are spreading open. The slit in the comptech bushings
are directly under load, the slit being straight down. These slits are
spreading open.
I'm ordering some suspension energy bushings, part # 9.5126.
The greasable type has larger bracket dimensions and will not fit. I
saw them at pep boys.
The energy suspension bushings are slit on the side as they
should be.
spreading open.
should be.
cycdaniel
12-17-2019 10:58 AM
k6biv
09-10-2015 06:37 PM
nuldabz
09-03-2015 05:49 PM
