Rear suspension makes "Clunk" noise
Old May 17, 2005 | 11:06 AM
kaikai114's Avatar
Got Milk???
I've installed the eibach prokit on stock suspension for about 2 months now. From the beginning, I've heard this slight "clunk cluck" when going over a bump coming from the rear right suspension. Didn't think it's a big deal until yesterday when I made a left turn over an uneven surface, i heard this really "loose clunk cluck" noise coming from rear middle or rear right. Oddly, this only happens when I make left turns, so I figured it's most likely to be rear right suspension since weight is shifted to the right when you make left turns. I've checked my trunk for anything loose even in the spare tire compartment, nothing. Anybody have any clue to what may be wrong, strut bar/springs or the multi-link section? Please help, thanks!
-KC
Old May 17, 2005 | 12:21 PM
ComptechTSX's Avatar
-KC
I have a similar noise on my car aswell...but i think mine might be from the compartment above the spare tire.....that area moves very easily when hitting a bump. U could try holding that down better with some weight ....and see if it still occurs.....but since urs in only when u make left turns...it might not be the same issue
Old May 17, 2005 | 12:27 PM
TSX 3Pedal's Avatar
Use all 3 Pedals at once
Make sure your rear sway bar end links aren't broken.
I use to experience this noise only when making right turns. The cause, broken right end link.
I got it replaced under warranty and now, there is no more noise.
Old May 17, 2005 | 01:34 PM
kaikai114's Avatar
Got Milk???
you're perfectly right dood, i just came back up from the garage and found the left sway end link snapped into 2 heading over to tustin acura tomorrow to get it fixed along with other issues. btw, do you have any creaks on the front 2 windows? thanks man!
-KC
Old May 17, 2005 | 01:55 PM
TSX 3Pedal's Avatar
Yea...this is how mine looked like:
As for the creaks, I have slight creaking. They havn't bothered me enough that I had to bring it in.
I'm glad to have helped you with your problem KC.
Later man.
Old May 17, 2005 | 03:38 PM
kaikai114's Avatar
Got Milk???
Later man.
My endlink split right in the middle, time for Comptech Swaybar. I wonder how I broke it in the first place.... was wondering if I overtorqued something while doing the suspension. gettin' my Injen CAI tomorrow! those of you in Irvine, watch out, it's gon get noisy for a while
-KC
Old May 17, 2005 | 11:02 PM
xizor's Avatar
Bye TSX, hello domestic?
-KC
the loud clunking is from the broken endlink, but the noises you heard before is from the spring full extending and moving in the perch. a rear sway bar will prevent it from extending so much and keep the noises down.
Old May 18, 2005 | 12:07 AM
kaikai114's Avatar
Got Milk???
now i really think oem swaybar is nothing but a piece of junk. i hardly push my car to the limits, maybe once since i first got my car and the endlink snapped. i've just got the comptech rear sway ordered this afternoon, hopefully the comptech wont break on me like the oem one.
Old May 18, 2005 | 12:18 AM
xizor's Avatar
well your end link broke, the comptech rear sway doesn't replace that. so you'll be stuck w/ another oem one again. make sure you get acura to warranty that before you put the comptech on
Old May 18, 2005 | 02:39 AM
kaikai114's Avatar
Got Milk???
I tried talking the dealer into paying me cash instead of giving me another oem swaybar so i can put it toward buying a new comptech sway. But they wouldn't do it, so tomorrow morning, they'll be putting in a replacement oem one. The comptech one will have to be done on my own next week.
-KC
Old May 18, 2005 | 09:32 AM
Dan Martin's Avatar
Photography Nerd
-KC
It's not your swaybar that broke, it's your endlink. You'll be getting another OEM endlink, not another swaybar.
Old May 18, 2005 | 11:00 AM
kaikai114's Avatar
Got Milk???
do endlinks break easily, or did i just drive too hard...?
Old May 18, 2005 | 11:01 AM
Dan Martin's Avatar
Photography Nerd
Apparently they break fairly easy since you're not the first to do it.
Feb 25, 2020 09:57 AM
wilztlxs
Dec 1, 2015 09:16 AM
Heyzuez20
Oct 14, 2015 07:18 AM
