Rear camber problem
Old Jul 16, 2008 | 08:26 AM
a3gus's Avatar
Rear camber problem
Hi all,
After a 4 wheels alignment, the service guy (not the dealer) says he's not able to adjust the camber angle to the specs (between -0.5 to -1.5 deg), presently is -1.72 deg left side and -1.95 deg right side. I believed that was BS so I called the Acura Service. They told me same thing... the upper arms are not adjustable and should be replaced. Cost: 115$ each plus labour. The Service Advisor told me that the mileage is too high for good will (TSB 06-007)
Why these upper arms are not adjustable???
Should I be worried about that (tires wear…)?? Do you have a cheaper fix to this problem? My car is not lowered. My TSX is 2004, 146,000km.
Thanks a lot.
Old Jul 16, 2008 | 08:55 AM
moda_way's Avatar
Yeah, there is a TSB on camber for the car and no, camber is not adjustable in the rear unless you get an Ingalls or SPC kit.
EDIT: Just noticed Acura said they will not good will you. There are a couple of sites that sell the Ingalls kit, most notably, MrHeelToe, our forum vendor. Prior to Marcus selling them, I used importhorizons.com.
Old Jul 16, 2008 | 09:00 AM
Simba91102's Avatar
Old Guy
Originally Posted by a3gus
Hi all,
Thanks a lot.
With that many miles (90.5K for those who like miles), it may be suspension wear but I doubt it. Of course that begs the question why the spec is so far out (each side should be -1; I think the range thing covers Acura's ass if it isn't screwed together right). And you were given accurate information about the non adjust-ability of the rear camber; it's not adjustable with the factory suspension. Anyway, you could go with an Ingalls camber kit, or live with it. Has it always been that far out? (the left side is almost 3 degrees off, that's allot). The -1.95 on the right side you could certainly live with without affecting tire wear too much. Sounds like there's something wrong on the left side though.
Old Jul 16, 2008 | 10:16 AM
a3gus's Avatar
Simba91102,
You say the left side is almost 3 deg out? How you calculated? It's only -1.72, in my opinion is better than right side (-1.95).
It's something that I dont't understand?
Old Jul 16, 2008 | 11:40 AM
2007CGPTSX's Avatar
B A N N E D
I actually have a brand new ignalls rear camber kit that i purchased a few months ago for sale. i thought that i was going to need the kit for the aspec suspension on my tsx but i did not. one box is opened, the kit has never been installed and all of the parts are in the original boxs along with the instructions i believe. i can let the kit got for 85$ shipped. PM me if anyone is interested.
Old Jul 16, 2008 | 02:47 PM
RkFast's Avatar
Unless this bugs the hell out of you, Id leave it. Hondas with DWS are notorious for their lack of adjustment points.
My Integra was "out of specs" on the camber front and back for years. Tires wore just fine......dead even.
Do the math...what is the cost of tires versus the cost of the control arms/kits and installation? For me with the Teg, the cost was the same as TWO sets of tires, each of with, even with the car "out of spec" lasted almost four years. So....and Im doing loose math here...youd need to burn through about two sets of tires over almost SIX years for the kits/control arms to "pay for themselves."
Not worth it, IMO.
Old Jul 16, 2008 | 03:16 PM
JTso's Avatar
Camber kit ($150) + installation is about the price of ONE OEM tire.
Old Jul 16, 2008 | 03:38 PM
LukeaTron's Avatar
Could it just be increased static sag in the suspension? Maybe you're springs are just tired after that many miles. Does the multi link suspension change camber at all when the springs compress or is it pretty much the same throughout the travel?
Old Jul 16, 2008 | 05:31 PM
Miamicarfan's Avatar
Doesn't the Service Bulletin cover just the "Right" rear upper control arm or both right and left?
Old Jul 17, 2008 | 05:02 AM
Simba91102's Avatar
Old Guy
Simba91102,
Sorry, my mistake. I thought the left spec was 1.72 (I missed the negative).
Old Jul 17, 2008 | 05:53 AM
aaronng's Avatar
Driver/Detailer
=1.9 is alright. I had -3.5 before. LOL. Got the Ingalls kit and everything was solved.
Old Jul 17, 2008 | 06:41 AM
RkFast's Avatar
Excuse me, kit, plus installation plus alignment is more than $225.
Old Jul 17, 2008 | 10:35 AM
JTso's Avatar
Camber kit ($150) + installation (~$50) + alignment (~$65) = ~$265
It's still way under your assessment of 2 sets of tires (8 tires).
Old Jul 17, 2008 | 05:11 PM
aaronng's Avatar
Driver/Detailer
I got my camber kit in and installed it myself for the price of one aftermarket tyre, much cheaper than the price of one OEM tyre.
Old Jul 29, 2008 | 05:59 PM
a3gus's Avatar
Thanks guys
mada51589
Jan 9, 2025 04:40 PM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
james357
Feb 13, 2016 02:37 PM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
d.lim
Sep 15, 2015 08:54 PM
