Rattle in the RT cat...
I've had my tsx up and down on lifts like a Duncan yoyo, for the past 3 weeks. All opinions are the 'rattle' is coming from my RT cat. RandomTech has said it could be a manufacturing defect but probably, a too rich fuel mixture (unburned gas to cause-overheating); that caused the 'strands' (non-ceramic) to separate from the inner wall. Anyone have similar circumstances with their cat? If its fuel management; wouldn't that be a faulty Hondata reflash? RT's tech guy said he has heard of that happening before. I'm sending RT jpgs of the cat this weekend. Apparently, the color of the external cat means something: Dark brown is no good. A 'honey' color is good.
Problem solved. What should have been done in the first place; remove the bolts to see what's causing the problem. Don't know why the shop that installed the RT cat put a thin, narrow ring gasket after the gasket kit at the cat & catback flange. So, the 3 bolts could never be tightened completely flush. The RT is fine. and the rattle gone. Curse that 'install' shop to hell.
In Gillette. Rich's Auto-but DON'T go there. I had them mount & balance my Faulkens, too. And within a week, I lost two lugs on my right-rear wheel. I received the latest help with fixing the rattle at the Strauss, in N. Plainfield, on Rt 22E. Didn't charge me. Just gave the mechanic $20. I would have boned-up, and installed the RT Cat myself-if I didn't have a neck operation back in June. I talked with a guy at Midas muffler_who works at 'Pride & Performance' in Keansburg, NJ. He said to come down and check it out. But thats a bit of a haul for me. Dave Trible, at Bridgewater Acura had a night crew that really looked after my TSX. And I keep him up-to-date on my mods. I'll see him for an alignment for my new Centerline wheels on order and install of my NST pulleys, when Marcus gets them in. Some places up on Rt 46 I want to check-out, too. TrixTrax in Woodbridge, is the only place I've heard that has a dyno.
marcelft
Jul 10, 2018 06:17 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
3GTLOwns
Sep 9, 2015 09:51 PM
