problems starting?
Old Apr 20, 2005 | 12:42 PM
dougw's Avatar
6th Gear
problems starting?
Anyone experienced this?
I have a 2005 TSX MT. I stalled it this morning and it took several tries to restart. I turned the key and nothing happened -- the starter did not engage. After about five tried it started and everything was fine.
When I got home I experimented -- shut the car off and immediately tried to restart -- and could duplicate the problem occasionally. The starter would not engage, then I would try again and it would. So same thing, but not as bad as when it had stalled.
I called the dealer and they said the electronics were probably "confused." They suggested waiting a few seconds before restarting, especially if the car has stalled.
Do you think that explanation makes sense?
doug
Old Apr 20, 2005 | 12:46 PM
05_TSX_GP's Avatar
Top notch 6MT
doug
Your dealer's probably right. The immobilizer may need few seconds to reset properly. Try removing the key from the ignition, pause, put back in and try again.
Old Apr 20, 2005 | 01:23 PM
TSX 3Pedal's Avatar
Use all 3 Pedals at once
^^ I don't think this needs to be done...
I've stalled a few times in traffic and when I went to start my car it started right away.
Maybe you should go to the dealer and let them check it out.
Old Apr 20, 2005 | 01:28 PM
leftride's Avatar
i want to ride my bicycle
damn 3 pedals
Old Apr 20, 2005 | 02:24 PM
05_TSX_GP's Avatar
Top notch 6MT
Originally Posted by virus7
damn 3 pedals
"Use all 3 Pedals at once" == "stalled a few times in traffic"
I still believe in my original answer, but never hurt to ask the dealer to get to bottom of it
Old Apr 20, 2005 | 03:45 PM
thS777's Avatar
Somewhat related on the topic. I noticed that every time I attempt to start the TSX, there is a few seconds lag before the engine is actually started.
I read in the manual that it can do this sometimes and it is normal. But it happens everytime, just wondering if this is normal. My previous three cars never had this characteristic.
Old Apr 20, 2005 | 03:51 PM
TSX 3Pedal's Avatar
"Use all 3 Pedals at once" = Heel Toe Downshifting ...or at least I try
Old Apr 20, 2005 | 04:04 PM
05_TSX_GP's Avatar
Top notch 6MT
I know I was just poking fun given what's written
I do heel-toe downshifting too when the occasion calls for it, mighty fun
Old Apr 20, 2005 | 04:05 PM
05_TSX_GP's Avatar
Top notch 6MT
I remember the manual says it has to do with the computer figuring out and setting up something for best emmision control
Old Apr 21, 2005 | 06:40 AM
miner's Avatar
When I purchased my '04 MT in May of '03 I had starting problems quite often. The culprit was a bad upper clutch AND lower clutch switches. No problems since replacing them.
Old Apr 21, 2005 | 11:14 AM
eburoon's Avatar
3 pedals and only ---- 1 right foot-- 1 left foot ---- the third one is missing????-- how can you drive such a car?????????
With my "AT" i have no problems.
Old Apr 21, 2005 | 07:05 PM
aaronng's Avatar
Driver/Detailer
My third leg is long enough..
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
